Results 1 to 6 of 6
    Banhammer Guest
    Teamspeak window is never active, help plz
    I'm having a truly bizarre issue with TeamSpeak.
    The window cannot be made active. I click, and nothing happens...the title bar stays greyed out. It cannot be brought to the front, cannot be used...the window exists, but it does absolutely nothing.
    TSClient.log is an endless repetition of lines exactly like this one:
    19-03-04 12:51:53,2836,WARNING,All,procedure TDICallBack.execute,"The operation had no effect." or "The device buffer overflowed and some input was lost." or "The device exists but is not currently attached." or "The change in device properties had no effect."
    I've tried uninstalling and reinstalling -- no luck. I've tried deleting TeamSpeak.conf...no luck.
    Fluxx Guest
    I am having the same problem... It happens when i minimize teamspeak, if i leave the window open it won't happen... Are you using Blackbox? I am, and it doesn't do it when i use explorer.
    Jun 2004
    USA
    It seems to happen to me too. I don't use explorer either, I use a combo of ObjectBar and DesktopX from Stardock...maybe thats why?
    Dec 2003
    USA Michigan
    i have the same problem and i use objectbar and i think its objectbar that does it because when i turn it off its fine.
    Oct 2002
    2,594
    what about answering the questions from the forum rules???
    I guess you're using win3.1 and that's why it doesn't work.
    ok, to be serious... you could try to delete your TeamSpeak.conf (search your hard-disk for it (hidden and system-folders included)) after stopping the ts-client. (this will reset the client.)
    cu
    SatanClaus
    Oct 2004
    Finland
    I have a same kind of problem too. TS client restarts, but the window isn't showing up, only the tray icon is visible. When I try to make the window visible by double clicking the icon or right mouse button/show, it just doesn't work After doing this the program appears in task manager, so I can choose it with alt+tab. The window stays invisible so there's not much to see.
    This problem occured after a long history of running TS well, I've not had this sort of problems before.
    I've tried uninstall + deleting the stuff that remains, and reinstalling the client software but without success.
    I don't seem to have the .conf file you mentioned, maybe because I haven't get to do any setting on my new install?
    edit: Aah I thought the file was supposed to be in TS folder.. I did a search, found it, deleted it and now it works
    Thanks!
  1. New Teamspeak Ability wanted !!
    By CMCT_Kirk in forum [TeamSpeak 2] General Questions
    Last Post: 01-09-2002, 17:43
  2. TeamSpeak Server won't report Statistics to your Webserver/PHP Script
    By T. Boonstra in forum [TeamSpeak Classic] General Questions
    Last Post: 21-06-2002, 21:00
