Results 1 to 5 of 5
    Jun 2004
    Sweden
    Mysql Oddity question regarding remote DB
    Hi i have a question about the mysql support.
    I have my TS installed on Win machine and succeded to let it interact with a MYSQL DB placed on a remote server.
    Reason is simple i want as much juice free from the TS server and be able to create a php form for Web admin the server settings direcly to the MYSQL.
    Now. it seems the TS need a direct local access to the .sql files ?
    Correct me if i'am wrong but it logs in nicely to my remote mysql but then yells about it cant gain access to the .sql here is a snippet from the log:
    I installed the DLL needed for the mysql and it logs in fine to the mysql (Checked my logs )
    -------------- log started at 02-06-04 17:27 -------------
    02-06-04 17:27:10,ALL,Info,server, Server init initialized
    02-06-04 17:27:10,ALL,Info,server, Server version: 2.0.20.1 Win32
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_read_servers.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_new_server.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_read_server_privilege.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_new_server_privilege.sql
    02-06-04 17:27:10,ALL,Info,server, Starting VirtualServer id:0 with port:8767
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_edit_server.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_read_channels.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_new_channel.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_read_bans.sql
    02-06-04 17:27:10,WARNING,Info,SERVER, Default VirtualServer created
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_read_clients_name.sql
    02-06-04 17:27:10,ERROR,All,SQL, SQL file not found ts2_new_client.sql
    02-06-04 17:27:10,WARNING,Info,SERVER, admin account info: username: admin password: farb16
    02-06-04 17:27:10,WARNING,Info,SERVER, superadmin account info: username: superadmin password: 1jgijo
    02-06-04 17:27:11,ALL,Info,server, Server init finished
    ________________________________________
    Also i send my .INI settings:
    [debug]
    MessageTypes=LMTALL
    MessageDepths=LMDALL
    [Main Config]
    ExternalIPDectection=1
    HTTPServer Port=14534
    HTTPServer Enabled=1
    DateTimeFormat=dd-mm-yyyy hh:nn:ss
    TCPQueryPort=51234
    AllowedClientNameChars=
    DisAllowedClientNameChars=()[]{}
    BoundToIp1=
    [WebPost]
    AdminEmail=admin@tgbf.org
    ISPLinkURL=na
    ISPName=Private
    ISPCountryNumber=2457
    Enabled=1
    PostURL=
    ListPublic=1
    UserAgent=teamspeak
    [log]
    access_r=0
    access_u=0
    channel_registerred=0
    channel_unregisterred=0
    sa=0
    chat=0
    kick_server=0
    kick_channel=0
    [Spam]
    max_commands=10
    in_seconds=2
    [DBEXPRESS]
    sqldir=mysql_sql
    Drivername=mysql
    Database=xxxxxx
    Hostname=xxx.xxx.xxx.xxx
    User_name=xxxxxx
    Password=xxxxx
    GetDriverFunc=getSQLDriverMYSQL
    VendorLib=libmysql.dll
    LibraryName=dbexpmysql.dll
    Active=1
    It would be very handy if it would be possible to set and save the mysql on a remote server to free off some memory of the DB and yet use the ones i allready have up .
    CHeers
    Apr 2004
    Dominican Republic
    115
    you need to burrow some files from the sqlite folder.
    Jun 2002
    Hamburg/Germany
    456
    Jun 2004
    Sweden
    Basicly u are telling me to put this: "sqldir=C:/Programme/Teamspeak2_RC2_1/mysql_sql/"
    and all should be fine . Excellent i will try that right away.
    Jun 2004
    Sweden
    Worked like a charm Case closed . Thx for the info ....
