Results 1 to 5 of 5
    Jun 2004
    wv
    TS problems (cant connect)
    I hope there is a good answer for what I am imagining is a stupid question.
    I am running the latest version of TS on a p2.8c, with a gig of RAM, 80 gig SATA, & an audigy soundcard. I have DSL service that is going thru my Linksys Router, & am using XP with the firewall turned off.
    Anytime I try to connect to a server that is using port 8767, it gives me the response that the server does not exist, or may not be running TS. Well, I went into my router menu & opened 8767~8767 on my internal ip (192.168.1.*) & still fail to connect. I set my PC in the DMZ & again, I get the message.
    I am a hopeless noob, in need of some help!!! Please tell me what to do before I throw my monitor thru the wall!!!
    thanks!
    Aug 2002
    Switzerland
    8,182
    when running only the client, no port forwarding is required. Now the only thing I can guess is that you still have a firewall blocking the connection (either win XP default firewall, an add. personal firewall, a firewall on your router,...). If you have zonealarm, you better do a search here as this one causes a lot of probs.
    Jun 2004
    wv
    Guldi,
    First off, thanks for your responce.. this problem is really makign me insane. The only two FWs I could have on my XP box, would be the one from the router, & the XP FW, which I believe I deactivated. I did that by going into tmy network proterties, clickign the 3rd tab (at work, cant recall its name) & unchecking the box that turns the FW on/off. Am I missing something in this?? IOs there something else I need to do?
    Jun 2004
    Pinole, California, USA
    163
    If this is at work, there is a possibility that the corporate firewall appliance is blocking everything except acceptable traffic (the way we do it) so the firewall folks would have to allow this.
    Jun 2004
    wv
    It wasnt.. I had changed a setting on my router when I first started troubleshooting, & I forgot to change it back... I am an idiot /beat self
  1. I can connect to my server but noone else can
    By Crombie in forum [TeamSpeak Classic] General Questions
    Last Post: 02-09-2005, 14:52
  2. can't connect
    By termipa in forum [TeamSpeak Classic] General Questions
    Last Post: 17-09-2002, 19:56
  3. Can one use TS2 to connect to older TS servers
    By BadNewsBoon in forum [TeamSpeak 2] Client Support
    Last Post: 02-09-2002, 17:28
  4. Cannot connect (error -10060)
    By vradi in forum [TeamSpeak Classic] General Questions
    Last Post: 17-07-2002, 21:32
