Results 1 to 7 of 7
    Jun 2004
    Florida
    mysql password problem
    I'm getting this:
    -------------- log started at 12-06-04 06:38 -------------
    12-06-04 06:38:42,ALL,Info,server, Server init initialized
    12-06-04 06:38:42,ALL,Info,server, Server version: 2.0.20.1 Win32
    12-06-04 06:38:42,ERROR,All,SQL, Database initialization error: EDatabaseError.dbExpress Error: Invalid Username/Password
    12-06-04 06:38:42,ERROR,All,SERVER, Start_Server: unable to open database
    12-06-04 06:38:42,ERROR,All,GENERAL, critical error, shutdown initiated
    but the thing is that i have tried multiple users and passwords including root to see if it would work. is there a certain way that i have to encode the password in the server.ini file?
    thanks.
    Aug 2002
    Switzerland
    8,182
    no
    have you given the user the right to access the specific TS database ? I had exactly this problem as well.
    Connect to your mysql server and test the login !
    Jun 2004
    Florida
    The user i set up works from the command line with no problem. And i know i've given that user the correct permissions. I've even triend root, which i know has no problems, but no success. Is there something that i'm over looking? The DB stores passwords encoded right? should i have the encoded password in the server.ini?
    here is what's going on:
    C:\>mysql -u teamspeak -pasdfasdf
    Welcome to the MySQL monitor. Commands end with ; or \g.
    Your MySQL connection id is 13 to server version: 4.0.20a-nt
    Type 'help;' or '\h' for help. Type '\c' to clear the buffer.
    mysql> use teamspeak
    Database changed
    mysql>
    but here's the response from ts. (server.log)
    -------------- log started at 12-06-04 11:36 -------------
    12-06-04 11:36:36,ALL,Info,server, Server init initialized
    12-06-04 11:36:36,ALL,Info,server, Server version: 2.0.20.1 Win32
    12-06-04 11:36:36,ERROR,All,SQL, Database initialization error: EDatabaseError.dbExpress Error: Invalid Username/Password
    12-06-04 11:36:36,ERROR,All,SERVER, Start_Server: unable to open database
    12-06-04 11:36:36,ERROR,All,GENERAL, critical error, shutdown initiated
    And my current [dbexpress] section in server.ini
    [DBEXPRESS]
    sqldir=C:/Program Files/Teamspeak2_RC2/mysql_sql/
    Drivername=mysql
    Database=teamspeak
    Hostname=localhost
    User_name=teamspeak
    Password=asdfasdf
    GetDriverFunc=getSQLDriverMYSQL
    VendorLib=libmysql.dll
    LibraryName=dbexpmysql.dll
    Active=1
    thanks.
    Apr 2004
    Dominican Republic
    115
    how many files do you have on the teamspeak\mysql folder? i think you need to burrow some files from the sqlite folder.
    Jun 2004
    Florida
    I copyed the files over from sqlite_sql.
    C:\Program Files\Teamspeak2_RC2\mysql_sql>dir
    Volume in drive C is Local Disk
    Volume Serial Number is 5855-CE0B
    Directory of C:\Program Files\Teamspeak2_RC2\mysql_sql
    06/12/2004 05:35a <DIR> .
    06/12/2004 05:35a <DIR> ..
    04/10/2003 10:34a 328 create_bans.sql
    04/10/2003 10:35a 739 create_channels.sql
    04/10/2003 10:35a 391 create_channel_privileges.sql
    11/18/2003 02:14p 426 create_clients.sql
    07/04/2003 08:19a 149 create_nicks.sql
    06/06/2003 08:28a 1,405 create_servers.sql
    04/10/2003 11:12a 3,499 create_server_privileges.sql
    07/12/2003 05:34p 199 create_settings.sql
    02/16/2003 10:43a 81 delete_ban.sql
    02/16/2003 11:34a 78 delete_ban_ip.sql
    02/03/2003 08:20a 204 delete_channel.sql
    07/19/2003 07:19a 139 delete_channel_privilege.sql
    02/03/2003 08:21a 194 delete_client.sql
    05/24/2003 09:33p 315 delete_server.sql
    02/01/2003 12:25p 467 edit_channel.sql
    02/03/2003 08:09a 240 edit_channel_privilege.sql
    02/02/2003 12:32p 195 edit_client.sql
    09/16/2003 07:54p 121 edit_client_lastonline.sql
    11/05/2003 07:38a 994 edit_server.sql
    02/26/2003 06:38a 3,512 edit_server_privilege.sql
    02/16/2003 11:22a 188 new_ban.sql
    01/31/2003 12:23p 562 new_channel.sql
    02/03/2003 08:08a 269 new_channel_privilege.sql
    02/02/2003 09:16a 240 new_client.sql
    06/06/2003 07:28a 968 new_server.sql
    02/19/2003 09:42a 3,651 new_server_privilege.sql
    02/04/2003 11:04a 60 read_active_servers.sql
    02/16/2003 10:44a 58 read_bans.sql
    07/02/2003 07:58a 97 read_channel.sql
    01/31/2003 12:00p 66 read_channels.sql
    02/03/2003 08:08a 141 read_channel_privilege.sql
    07/19/2003 07:04a 609 read_channel_privileges.sql
    02/02/2003 08:08a 63 read_clients.sql
    02/10/2003 07:48a 92 read_clients_id.sql
    02/02/2003 09:03a 90 read_clients_name.sql
    07/21/2003 08:48a 710 read_client_channels_privileges.sql
    02/02/2003 08:09a 124 read_client_login.sql
    01/30/2003 10:36a 56 read_server.sql
    02/10/2003 09:05a 26 read_servers.sql
    02/10/2003 08:55a 57 read_server_port.sql
    02/05/2003 08:46a 99 read_server_privilege.sql
    09/14/2003 07:22a 58 remove_bans.sql
    02/28/2003 07:05p 164 remove_moderatedattribs.sql
    08/01/2003 07:37a 93 search_client.sql
    05/21/2003 08:01a 1,696 upgrade_1.sql
    06/06/2003 07:50a 1,935 upgrade_2.sql
    11/18/2003 02:17p 656 upgrade_3.sql
    47 File(s) 26,504 bytes
    2 Dir(s) 13,539,016,704 bytes free
    Jun 2004
    Florida
    Any ideas?
    Jan 2004
    Ehhh
    I have the same problem !
    I have a Teamspeak Server running at home and i want to have
    it connected to the MySqlDB on my webspace.
    I get the same reply but i can login manually.
    [DBEXPRESS]
    sqldir=mysql_sql
    Drivername=mysql
    Database=teamspeakdb
    Hostname=mypage.com
    User_name= teamspeak
    Password= abcdef
    VendorLib=libmySQL.dll
    Active=1
    ....... really confusing
    -------------- log started at 23-06-00 15:16 -------------
    23-06-00 15:16:50,ALL,Info,server, Server init initialized
    23-06-00 15:16:50,ALL,Info,server, Server version: 2.0.20.1 Win32
    23-06-00 15:16:52,ERROR,All,SQL, Database initialization error: EDatabaseError.dbExpress Error: Invalid Username/Password
    23-06-00 15:16:52,ERROR,All,SERVER, Start_Server: unable to open database
    23-06-00 15:16:52,ERROR,All,GENERAL, critical error, shutdown initiated
  1. Mysql Oddity question regarding remote DB
    By RikardF in forum [TeamSpeak 2] Server Support
    Last Post: 02-06-2004, 12:15
  2. Overall Server Password
    By nightmarepm in forum [TeamSpeak 2] General Questions
    Last Post: 10-09-2002, 16:12
  3. Overall Server Password
    By nightmarepm in forum [TeamSpeak 2] Client Support
    Last Post: 10-09-2002, 12:25
  4. Bizarre Choppy Problem
    By AngusHeaf in forum [TeamSpeak Classic] General Questions
    Last Post: 03-07-2002, 08:11
