Results 1 to 4 of 4
Thread: Connection timeout!
13-06-2004, 14:51 #1
-= TeamSpeak User =-
- Mar 2004
- Location
- Croatia
- 21
Connection timeout!
I normaly speaks with my friends on my server and after few minutes server crushed and we can connect any more,but when I shutdown my teamspeak server and turn it on again it work but only for few minutes and then the same problem show again can someone tell me how to fix that or do something.THANKS
14-06-2004, 16:21 #2
Try changing to Codecs used in the default channel. Your system may not like using the one you are currently using.
You can do this by opening the client, logging onto your server, right click on the default channel, Click on Edit Channel, and select a different Codec in the drop down box.
14-06-2004, 16:23 #3
- Mar 2004
- Location
- Croatia
- 21
Question
What codec do you suggest?
Originally Posted by Skratch1320
14-06-2004, 16:49 #4
I use Speex 12.3 Kbit on my channels, it works for me with no problems.
Connection Timeout
By Bullitt in forum [TeamSpeak 2] Client SupportReplies: 4Last Post: 24-11-2010, 16:03 -
Possible Timeout Issue
By Gooby in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 14-06-2004, 17:05 -
Need Help restricting registered members access to "Get Connection info"
By Kitaro Saji in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 01-06-2004, 07:39 -
Timeout Thread
By Broder in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 29-08-2002, 20:22
