Results 1 to 4 of 4
    Mufosa Guest
    Problem with settings not saving
    OK everytime i open up TS it's setting are set to my orignal settings. Even if i change them they will change right back when i restart TS and wont save it also effects in the ADD SERVER area it wont save ip address or anything. It just automatically resets back to an ip address i dont use anymore can u help me with the problem. oh yeah also i tried uninstalling and reinstalling it didnt work. Thank you for your time
    Mar 2005
    The Netherlands
    Same problem here!!! Have to refil all fields again and local Adressbook doesn't save
    I have the same problem. I checked the TeamSpeak.Conf file in my (windows) documents and settings folder and unchecked the readonly limitation. That didn't work. Now I have to adjust my settings and add all my servers in my local adressbook each time I restart TS2. I have searched the forums but couldn't find a sollution to this problem. Please help anyone, it is a big hassle re-adding and re-adjusting my servers and settings.
    Thanx'zz at forehand!!!
    Toniezz.
    Mar 2005
    The Netherlands
    Solved problem
    Check ur time. My year of dat was 2165. Dunno how that happende but when I put it back to the time wich is now (2005) TS2 is able to save my settings correctly.
    Gl.
    m&m's Guest
    if you think your teamspeak.conf is currupted deleat it and restart ts it should make you a new 1 , add a few servers to the adress book and join them , exit them , shut down ts client , restart ts and see if there still there ?
  1. Server Settings Problem
    By Cambridg in forum [TeamSpeak 2] Server Support
    Last Post: 13-08-2003, 18:51
  2. Problem: Höre nach ca. 20-30min niemanden mehr im TS2
    By LOC-MAXX in forum [TeamSpeak 2] Client Support
    Last Post: 02-07-2003, 15:49
  3. RC2 Server Not Saving Settings
    By Imortal in forum [TeamSpeak 2] Server Support
    Last Post: 18-05-2003, 12:27
  4. AUDIGY 2 & TS weird very (!) annoying problem!!!
    By doc.pepper in forum [TeamSpeak 2] Client Support
    Last Post: 30-04-2003, 17:06
