Results 1 to 3 of 3
24-06-2004, 00:43 #1
-= TeamSpeak User =-
- Jun 2004
- Location
- USA
- 2
Start stop script for TeamSpeak daemon (init)
The script to handle starting and stopping of TeamSpeak that comes with the latest versions has a lot of problems. Namely, it doesn't work with the init system on Linux and therefore won't start TS when your system is rebooted. And the restart option doesn't work correctly.
This version fixes those issues and others and cleans up some of the code.
This script should go in "/etc/init.d/tss". Make links in "/etc/rc3.d" like "ln -s ../../init.d/tss S85tss" and "ln -s ../../init.d/tss K15tss". Make sure to change the config section. You should install TeamSpeak to run under some user - NOT ROOT - like voice or tss or something. Change "USER" to that username. Change "DIR" to the path to your TeamSpeak directory.
Now do "service start/stop/restart tss" (pick one of start, stop, or restart) as root or a sudo priviledged user. This is how it *should* be.
Cheers.
Derek "Cybernaut"
www.DigitalNines.com - Web Hosting, Game Hosting, etc.
Edit: not a suggestion, moved.Code:#! /bin/bash # Copyright (c) 2004 TeamSpeak team All rights reserved. # # Author: pwk.linuxfan 2004 # Modified by Derek "Cybernaut" Jackson - www.DigitalNines.com # # chkconfig: 345 85 15 # description: Runs and kills TeamSpeak Voice server at boot time and shutdown. # Source function library. #. /etc/rc.d/init.d/functions # START OF CONFIG SECTION # WARNING ! For security reasons we advise: DO NOT RUN THE SERVER AS ROOT USER=voice DIR=/home/voice/tss2_rc2 # END OF CONFIG SECTION # See how we were called. case "$1" in start) if [ -e $DIR/tsserver2.pid ]; then echo "tsserver2.pid already exists...server already started ?"; echo "If you are sure the server is not running, delete tsserver2.pid" exit 1 else if [ "$UID" = "0" ]; then for c in $(seq 1 10); do echo -n "!" sleep 1 done echo ! fi echo "Starting the TeamSpeak Voice server..." if [ -e $DIR/server_linux ]; then if [ ! -x $DIR/server_linux ]; then echo "server_linux is not executable; trying to set it." chmod u+x $DIR/server_linux fi if [ -x $DIR/server_linux ]; then WD=`pwd` cd $DIR su $USER -c "$DIR/server_linux -PID=tsserver2.pid" & cd $WD else echo "server_linux is not executable; fix this." exit 4 fi else echo "Couldnt find server_linux." exit 5 fi fi ;; stop) if [ -e $DIR/tsserver2.pid ]; then echo -n "Stopping the TeamSpeak Voice server..." if ( kill -TERM `cat $DIR/tsserver2.pid` ); then for c in $(seq 1 300); do if [ -e $DIR/tsserver2.pid ]; then echo -n "." sleep 1 fi done fi if [ -e $DIR/tsserver2.pid ]; then echo "server does not shutdown cleanly - killing" kill -KILL `cat $DIR/tsserver2.pid` rm $DIR/tsserver2.pid sleep 5 else echo "done" fi else echo "tsserver2.pid is missing; is the server stopped already?" #exit 7 - Should not be here as doesn't allow restart if server is already stopped. fi ;; restart) $0 stop && $0 start || exit 1 ;; status) if [ -e $DIR/tsserver2.pid ]; then echo "The TeamSpeak Voice server is running." exit 0 else echo "The TeamSpeak Voice server is stopped." exit 3 fi ;; passwords) if [ -e $DIR/server.log ]; then date=$(cat $DIR/server.log | grep "admin account info: username: admin" | tail -n 1 | sed "s/^\([0-9]\+-[0-9]\+-[0-9]\+ [0-9]\+:[0-9]\+:[0-9]\+\).*$/\1/") spass=$(cat $DIR/server.log | grep "superadmin account info: username: superadmin" | tail -n 1 | sed "s/^.*username: superadmin password: \([a-z0-9]\+\).*$/\1/") pass=$(cat $DIR/server.log | grep "admin account info: username: admin" | tail -n 1 | sed "s/^.*username: admin password: \([a-z0-9]\+\).*$/\1/") echo "Following passwords were generated on $date" echo "superadmin = \"$spass\"" echo "admin = \"$pass\"" else echo "server.log not found; maybe the server has not been started yet?" exit 1 fi ;; *) echo "Usage: $0 {start|stop|restart|status|passwords}" exit 2 esac exit 0
21-10-2004, 22:39 #2
- Sep 2002
- Location
- Milano, Italy
- 7
Nice one, Cybernaut; only the double quotes in the activation command didn't work for me... anyways, great job. Perhaps it's also worth to mention that you can register the script with 'chkconfig --add scriptname' on FC/RH, so that you can manage TS activation/deactivation with the Services graphical interface. Now it runs harmlessly as 'nobody' on my box.... thanks to you
11-11-2004, 17:07 #3
- Jun 2004
- Location
- VA
- 13
Thanks dude...I kinda got a headache trying to find out why mine wasn't working.
Thanks.
Workng Mandrake 10.....waddatah!!
Need help on a start stop script.
By Jere in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 17-03-2004, 06:08 -
[debian]Start/stop script
By muldereric in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 03-02-2004, 12:12 -
Teamspeak RC2 daemon fails to start
By Toff in forum [TeamSpeak 2] Server SupportReplies: 7Last Post: 03-03-2003, 01:35 -
Cant start -> "Error stating daemon. Aborted"
By swafnir in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 17-09-2002, 18:15 -
Start script..
By NitroSniper in forum [TeamSpeak 2] Addons & ScriptsReplies: 3Last Post: 27-08-2002, 07:12
