Results 1 to 7 of 7
    Jul 2004
    New Zealand
    Strange Mouse problem in TS only!
    Very strange Mouse problem/
    I have a logitec Wired Optical MouseMan Wheel.
    Running Windows 2k
    Latest Logitec Drivers (downloaded them like last week)
    700+ mb DDR ram
    AMD 1800+ XP cpu
    The problem I am expericing in TS is strange and I'm sure it never happened when I first installed TS.
    What happens is, if I click the main TS window, my mouse sensitivity drops so low its very hard to move my mouse around windows. But if I click outside of the TS window (or click the TS tray icon) my mouse sensitivity magically goes back to normal and everything is ok.
    Can anyone suggest any help? I have tried reinstalling TS that didn't help.
    Cheers.
    Jul 2004
    New Zealand
    *bump*
    May 2005
    The Netherlands
    7
    I have this problem as well. However, it seems no one has found a fix yet. My specs:
    Microsoft Windows XP,
    AMD 64-bit 3200+ processor,
    1GB DDR 400 memory,
    Geforce 6800 Ultra graphics card,
    MSI K8N Neo Platinum motherboard,
    Samsung 710N LCD monitor (not relevant ),
    Logitech MX510 mouse with latest drivers
    This problem is caused by TeamSpeak, but affects my overall mouse sensitivity, which means during games as well. Very annoying indeed.
    Aug 2004
    Ontario, Canada
    46
    It does indeed sound like this problem is with TeamSpeak, but I think the overall cause is the latest Logitech drivers you both speak of.
    I highly recommend visiting the Logitech website and seeing if you can find a previous driver version. Install it and see if that helps. If it does turn out to be the new drivers, I'm sure an email over to Logitech notifying of the issue couldn't hurt.
    May 2005
    The Netherlands
    7
    That doesn't work, I did a format of my hard drive and re-installed everything several weeks ago. Without using the newest drivers, the problem still existed.
    Oct 2005
    Western Australia
    8
    Quote Originally Posted by CdnBacon
    if running XP you can roll back driver to the previous one in the mouse settings
    Oct 2005
    Denmark
    Quote Originally Posted by jared_nz
    Running Windows 2k
    700+ mb DDR ram
    AMD 1800+ XP cpu
    Cheers.
    Its the "detect game and disable mouse accel"-setting in the logitech drivers.
    I had the problem your describing once, and unticking that feature made the problem go away.
  1. Strange connection problem... please help.
    By Frostfire in forum [TeamSpeak 2] Client Support
    Last Post: 19-07-2006, 10:53
  2. Mouse Problem with Teamspeak
    By Paulpeter in forum [TeamSpeak 2] Client Support
    Last Post: 30-08-2003, 13:23
  3. Strange problem
    By Grim in forum [TeamSpeak 2] Client Support
    Last Post: 31-03-2003, 17:42
  4. Problem with mouse acceleration and teamspeak
    By sneax in forum [TeamSpeak 2] Client Support
    Last Post: 07-02-2003, 23:24
