Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Sep 2002
    mtl
    10
    Thumbs down TS2 server admin problem.
    I am using ts as a client for a long time , but the server is a real pain.
    ANYBODY can tell me where is the manual???
    I'm tryn to be adin but i just can't , i have look on the server.txt for the password but it won't work. I have reinstall TS2 a lots of time.
    I realy don't understand.
    Sep 2002
    mtl
    10
    Can anyone tell me why the hell TS2 create FILE on server.txt in the DESKTOP and in the c:\ ???????????????????????????
    I have try those password to and they won't work.
    What the hell is that, you sure ts2 is compatible whit windows2000???
    Sep 2002
    Va
    6
    Exclamation
    I am having the same problems. The server works fine, and then all of the sudden the admin pw is incorrect, and it loses all of the reg users names and pw's also. I don't quite understand it. Sometimes reinstalling works, other times it doesn't. I though it was because I was on win2k but looks like im not the only person having this problem
    Sep 2002
    mtl
    10
    I have do a search on the disk for SERVER.LOG and i have found 4 location of the file.
    I have try all other password on each file and i finaly found one working. BUT WHAT THE HELL THIS FILE WAS DOING UNDER MY WINDOWS2000 ADMINISTRATOR COMMUN FILE????
    Even if the password seams to be good , but TS2 server can't find the HTML page , it seams to search those page where the server.log is but in fact those page are on the TS2 directory.
    I give up
    word to the creator ---------------> before publish somethings .... try it and fix it , btw a MANUAL OF HOW IT WORK should be intelligent.
    Jun 2002
    Houston, Tx
    170
    you need to correct the startin properties of the shortcut. right click on the shortcut that TS 2.0 server made on your desktop and hrm bah easier to just delete the shortcut the open explorer and goto the directory you installed TS 2.server to and create a new shortcut.
    Sep 2002
    mtl
    10
    right it work now , thanks.
    For the manual , do you know where i can get it or there no manual?
    Sep 2002
    Va
    6
    How would updating the shortcut help anything? If the server.log is in a different directory other then the one TS Server is installed to? And why would only machines running win2k have a problem where TS 2.0 just forgets all the pw's? Is this a known bug or something new?
    Sep 2002
    mtl
    10
    LTD spike , i don't know.
    I have just delete all SHORTCUT of TS2server , in start menu include , after that i have create a shortcut on the directory of TS2 and i ran the program whit the shortcut on the TS2 , and all work .
    It seams that TS2 save server.log , server.ini and server.db from where it was open , its a funny bug trought...
    Jun 2002
    Houston, Tx
    170
    yes it is a bug in RC1 that is well known and will be corrected in RC2
    Aug 2002
    Austria
    7
    Solved that: The icon that TS2 Server createas at the desktop is the problem. When you start over these, TS2 creates a new server.db and server.ini at the desktop.
    Solution: Delete this and make a new yourself by drag and drop the server_windows.exe to the deskttop. This icon will work.
    Sep 2002
    mtl
    10
    Maybe if you put a readme.txt whit the package for windows2000 user...!?
    Jun 2002
    Krün / Germany
    1,965
    the installed link file is fucked up
    thats the problem. will be fixed with next official release.
    Aug 2002
    Austria
    7
    And pls fix the not editable Server.ini too. Thats not solved yet...
    Aug 2002
    Switzerland
    8,182
    nooooo...
    args.... thats a **** bug !!!
    since now I reinstalled the server EVERYTIME I had to use it. I used the "link" it created under Start -> Programs and this sems to be buggy too.
    what a dame bug :-)
    and I stupid old donky falled over it day by day.... *slap*
    thx to "solve" this prob (by starting it from the "real" .exe ît works).
    Aug 2002
    C-A-N-A-D-A
    14
    Actually If You Tryed To Edit The Server.ini File You Can You Just Need To Know How And What To Edit. Do You Really Think All These People Did It Through The Admin Panel? I Doubt It.
  1. Router problems
    By bigteam0385 in forum [TeamSpeak 2] Server Support
    Last Post: 24-05-2011, 10:53
  2. How to Install TS & MySQL 4 Properly
    By DOMINATION in forum [TeamSpeak 2] Server Support
    Last Post: 15-09-2009, 01:24
  3. Server Issue's When PC Reboots
    By gokub27 in forum [TeamSpeak 2] Client Support
    Last Post: 14-09-2006, 21:32
  4. cant open admin with ts2 server?
    By gunnerman009 in forum [TeamSpeak 2] Server Support
    Last Post: 17-11-2004, 23:07
  5. Problem Logging In to Server Admin Page
    By DaTomi in forum [TeamSpeak 2] Client Support
    Last Post: 16-01-2003, 19:44
