Results 1 to 13 of 13
    Jul 2003
    United Kingdome
    6
    LAN hosting problems please help
    Hi all
    I have 2 computers, one of which(computer1) is connected to the internet 512k DSL and another(computer2) one is in LAN network. Computer1 is an internet server for computer2. I'm running TS Server on computer2 but my mates and i cannot connect to it by my external ip, i only can connect by my local ip which is 192.168.0.1. I have all my firewalls switched off. Please help me.
    m&m's Guest
    Quote Originally Posted by juran
    Hi all
    did you open the server ports in the nat of computer1 ? so the server ports would be open to the net ? ports 8767 & 51234 udp cp1 is the router for pc2 so you need to open ports for the server to see the outside world & outside world to see pc 2 and your only ip to conect is 192.168.0.1 your mates will use your real world ip after you set ports open
    Feb 2004
    USA
    239
    Yes, you must use your internal ip for YOU to connect. Most routers to not allow people to use their external ip to "loop back" to their internal ip.
    Jul 2003
    United Kingdome
    6
    guys but what is the nat and how do i open my ports??? Please tell me coz im not very good at network stuff. All my firewalls are switched off so all the ports must be open, i think. Please help me in this guys.
    Aug 2002
    Switzerland
    8,182
    NAT, Google is your friend, why write something down which is available in thousands of places ?
    Your router manual will tell you how to setup the port forwarding. Simply forward (forward is NOT equal to open a port) the TS server port (default 8767) to your TS servers LAN IP in your router.
    Jul 2003
    United Kingdome
    6
    Thanx guldi. But i havent got a router i use my computer1 as my server for the internet to computer2(where I host the TS server), and my computer1 is connected to the internet through broadband modem 512k, i have no router, hub or switch. Both my computers are connected together through normal networkcard.
    Jul 2003
    United Kingdome
    6
    guys but where can i find NAT on my computer and how can i access it?? Im very sorry but im new in networking
    Feb 2004
    USA
    239
    Well if you don't have a router, i wouldn't think you would have NAT. Do you have ***ALL*** firewalls disabled ?
    Jul 2003
    United Kingdome
    6
    yes all my firewalls are desabled but it still doesn't work.
    Aug 2002
    Switzerland
    8,182
    then your PC 1 is most surely doing NAT (using ICS or an other SW doing NAT ?). As you stated you use the IP 192.168.0.1 inside your LAN, you must have something doing Network Adress Translation as such an IP can not be used in the WWW.
    You should consult the Help of ICS or the manual to the NAT SW you use. If you use ICS, you could do a search, I'm pretty sure you'll find some hints here.
    Jul 2003
    United Kingdome
    6
    Thanx guys. ive found how to do the port forwarding, but which port is external and which one is internal, please give me the number of the port i have to forward. Thanx very much guys.
    m&m's Guest
    8767 and 51234 both udp
    Dec 2003
    England,Alfreton
    Right your LAN coputers can connect through the LAN ip which 192.168.0.1
    but make sure your router is allowing the port number for servger to pass through make sure theres no fire walls interrupting if they r the ports r ts server port number default 8767 & 51234, 8767 is your UDP and 51234 is TCP
    after all that your internet ip not your LAN ip i.e 82.2.236.149:8767
    thats the ip your mates should connect to (Internet IP)
  1. Linux server and Windows client no go on LAN
    By Thetargos in forum [TeamSpeak 2] Server Support
    Last Post: 05-07-2004, 21:52
  2. hosting at a lan party
    By UI.-sk8r_guy74 in forum [TeamSpeak 2] Server Support
    Last Post: 20-05-2004, 09:53
  3. connection problems outside lan
    By slat3r in forum [TeamSpeak Classic] General Questions
    Last Post: 18-05-2004, 11:10
  4. Problems hosting TS
    By Eferno in forum [TeamSpeak 2] Server Support
    Last Post: 08-02-2004, 11:44
