Results 1 to 4 of 4
28-10-2004, 12:42 #1
Client says webpost quit working... HELP
I have a client who states that he has this as his webpost URL...
http://www.xxx-xx.com/73/webpost <--- x's just replace his info
He says it was working fine until recently and then it quit working.
I have suggested he try...
http://www.rfc-hq.com/73/webpost/webpost.php
He says he did but the same result. Nothing displaying.
Any ideas?
28-10-2004, 13:14 #2
-= TeamSpeak User =-
- Oct 2004
- Location
- USA
- 7
sounds logical, however why are you protecting the URL? Maybe we can check to make sure it is correct. Makesure webpost.php exists or something.
28-10-2004, 16:15 #3
Sorry..that was a dumb thing of me to do... However
I did post it in the 2nd link provided.
Not sure if that is what you are referring to or not?
Thanks for trying to help.
NOTE - He did say that is used to work, and now it doesn't.
29-10-2004, 13:32 #4
It is now working. Here is a tip...
If you reboot the server, check the webpost button to make sure it didn't reset to an OFF state.
We re-activated it and all is good.
Mic is not working at all!!
By kennec01 in forum [TeamSpeak 2] Client SupportReplies: 0Last Post: 13-04-2004, 03:00 -
Webpost link not working.
By Prophet in forum [TeamSpeak 2] Addons & ScriptsReplies: 0Last Post: 22-01-2004, 17:57 -
Webpost not working after moving to chroot
By mjrwoody in forum [TeamSpeak 2] Addons & ScriptsReplies: 0Last Post: 23-10-2003, 00:53 -
Connect problems, winroute firewall, ts2 rc2
By DarkAgression in forum [TeamSpeak 2] Server SupportReplies: 28Last Post: 18-04-2003, 16:39
