Results 1 to 2 of 2
04-11-2004, 21:18 #1
-= TeamSpeak User =-
- Nov 2004
- Location
- italy
- 1
hi i have problem with router and TS
-------------- log started at 04-11-04 22.11 -------------
04-11-04 22.11.41,1556,DEBUG,All,Startup,Client version 2.0.32.60
04-11-04 22.11.41,1556,DEBUG,ProcedureInfo,Client Open,Creating and starting threads
04-11-04 22.11.43,1556,DEBUG,All,TDSoundIn.Open,opend direct Capture 8bit=0 , 11khz=1
04-11-04 22.11.52,1264,WARNING,All,procedure TDICallBack.execute,"The operation had no effect." or "The device buffer overflowed and some input was lost." or "The device exists but is not currently attached." or "The change in device properties had no effect."
04-11-04 22.12.01,1556,DEBUG,All,TMainForm.FormDestroy,FCal lbackSynchronizer.Free done
04-11-04 22.12.01,1556,DEBUG,All,TMainForm.FormDestroy,FSou nd.Free; done
04-11-04 22.12.01,1556,DEBUG,All,TMainForm.FormDestroy,FSou ndNotifications.Free done
04-11-04 22.12.01,1556,DEBUG,All,TMainForm.FormDestroy,FWav eSaver.Free done
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active FClientReadThread.waitfor
04-11-04 22.12.01,1440,DEBUG,All,TClientReadThread.Execute, leaving
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active FClientReadThread.freeing
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active FClientReadThread.Freed
04-11-04 22.12.01,644,DEBUG,All,TClientEventThread.Execute, Close confirmed
04-11-04 22.12.01,724,DEBUG,All,TClientWriteThread.Execute, Close confirmed
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active closed buffer
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active FClientWriteThread.Freed;
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active FClientEventThread.Freed
04-11-04 22.12.01,1556,DEBUG,All,TClient.Destroy,active destroyed buffer
--------------- log ended at 04-11-04 22.12 --------------
router trust...
asdl
04-11-2004, 23:39 #2m&m's Guest
from inside the lan use the lan ip the 192.x.x.x # or 10.x.x.x or even the loopback ip of 127.0.0.1 if your client and server are same pc
