Results 1 to 3 of 3
    Nov 2004
    USA
    help change default port
    I have searched through all of these forums. All data amounts to nothing, so I will post my findings and hopefully find the proper answer.
    What I want to do:
    Change the port that the server accepts connections on. Currently it is 8767.
    Things I have tried:
    -under superadmin edit the line "Server UDP Port" from its default of '8767' in the web administration interface to a port of my choosing. I hit 'save' and get this reply in a web page:
    "if you want to edit udpport, please stop first the server
    CONTINUE"
    So I go to stop the server, but of course the web admin no longer functions. So I try to manually add this line to the server.ini file...
    ServerUDPPort=<port of my choosing>
    I then start the TSRC2 server back up ./teamspeak* start
    Then I go back to the web interface and it is still a default port of 8767. Also my Teamspeak client connects on port 8767 after I have made the changes.
    It seems like a neverending loop of getting nowhere. All of the information in these forums on this topic are absolute junk. Sure I have tried them all, but none of them work.
    Can all of us people get a real answer? Maybe we can get a sticky on "Changing default port" as alot of people have requested help and got none. I probably probed through about 15+ threads on the same topic, all leading to nothing.
    Aug 2002
    Silicon Valley
    45
    Don't stop the TS process
    In the WebAdmin on the Server Selection screen, click the Stop button to stop a TS server, process keeps running, then change UDP port
    Nov 2004
    USA
    Once again I was working too hard.
    Thanks.
  1. change TS default port
    By cynicalscope in forum [TeamSpeak 2] Server Support
    Last Post: 01-06-2004, 10:39
  2. changing default port
    By MrTee in forum [TeamSpeak 2] Server Support
    Last Post: 29-03-2004, 22:10
  3. Linux server default configuration change
    By BarryMead in forum [TeamSpeak 2] General Questions
    Last Post: 25-05-2003, 20:36
