Results 1 to 4 of 4
13-01-2005, 12:05 #1
-= TeamSpeak User =-
- Jun 2004
- Location
- china
- 5
Many TeamSpeak Server Many IP Address Help Me!
One Net card
Many IP Address
Can run Many TeamSpeak Server??
Each one TeamSpeak Server To one IP Address
help me ! Detailed
Thank!!!!!
13-01-2005, 13:55 #2
-= TeamSpeak Guru =-
- Aug 2002
- Location
- Switzerland
- 8,182
you can either:
1) run several TS server's on one IP and use different ports (setup new servers in the webinterface on diff. ports, superadmin rights required). See "superadmin" section of the server manual.
2) or you can install several TS instances on one PC / server and bind each of them (check server.ini: bindtoIP1,...) to one specific IP.
Usually way 1) is choosen as you do not have that many IP interfaces in one server.
13-01-2005, 15:02 #3
- Jun 2004
- Location
- china
- 5
Thanks
How to install a SERVER to use an IP address?
Each SERVER uses the different IP address ?
13-01-2005, 15:27 #4
- Aug 2002
- Location
- Switzerland
- 8,182
I answered this in my last thread under 2)
Originally Posted by infall
per default the TS server uses (listens) on all IP interfaces in your machine, unless you bind it in the server.ini to listen only on one (or more) specific IP's. It's a setting you have to edit in the server.ini file.
only if you install the TS server several times but then do NOT forget to set the bindToIP in the server.ini for each server installation to a different IP, the installation process of the TS server will not do this for you (see above the default behaviour of the server !).Each SERVER uses the different IP address ?
teamspeak server help ! ?
By jimstukken in forum [TeamSpeak Classic] General QuestionsReplies: 8Last Post: 15-09-2005, 12:45 -
TS server and wn 98 probs ?
By ghboom in forum [TeamSpeak 2] Server SupportReplies: 0Last Post: 30-05-2003, 06:05 -
Problem with teamspeak server
By MrIbra in forum [TeamSpeak 2] Server SupportReplies: 3Last Post: 17-09-2002, 20:07 -
TeamSpeak Server won't report Statistics to your Webserver/PHP Script
By T. Boonstra in forum [TeamSpeak Classic] General QuestionsReplies: 0Last Post: 21-06-2002, 21:00
