Results 1 to 8 of 8
Thread: Administrative Problems
13-01-2005, 13:08 #1
-= TeamSpeak User =-
- Jan 2005
- Location
- U.S.
- 5
Ok, I made a new super admin login and password, and after I did that, I deleted the old super admin and logged out. So then I tried to log in as my new admin and i couldnt log in. I don't know what happened, and ive never had a problem before with teamspeak (this is my first time running a server) so i shut down my server which kinda upsets my clan so pls help me out soon.
13-01-2005, 13:58 #2
-= TeamSpeak Fanatic =-
- Jan 2003
- Location
- Germany
- 4,140
Maybe you got the password wrong? Too bad there's no other super admin account left that you can use to reset the password.
Probably you're quicker off deleting the server.ini, server.dbs and server.log to reinitialize the server.
13-01-2005, 14:02 #3
-= TeamSpeak Guru =-
- Aug 2002
- Location
- Switzerland
- 8,182
would first try a:
- stop server
- open server.dbs with a text editor (admin / superadmin pwd's are there in plain text => get password)
- start server
- try login
13-01-2005, 14:04 #4
- Jan 2003
- Location
- Germany
- 4,140
That won't be much help since Ethiz already deleted the original superadmin user.
14-01-2005, 02:26 #5
- Jan 2005
- Location
- U.S.
- 5
ya that would help, where are those files at??? heh, im a noob aint i
14-01-2005, 09:19 #6
- Aug 2002
- Location
- Switzerland
- 8,182
aren't the passwords of all users in plain text in the server.dbs ? He could get out the password of the new superadmin he created ?
Originally Posted by Brain
@|sw|Ethiz
the files are of course in your TS server folder.
As you don't seem to be able to handle the file search function of your OS, it may be probably easier for you to reinstall the server as Brain recommended (or was this question just laziness ??)Last edited by guldi; 14-01-2005 at 15:01.
14-01-2005, 12:41 #7
- Jan 2005
- Location
- U.S.
- 5
Now i got more of a problem. I found the files but when i got to the user section, the superadmin i created isnt there. Is it possible to creat a super admin inside this file?
14-01-2005, 14:59 #8
- Aug 2002
- Location
- Switzerland
- 8,182
very well !Now i got more of a problem. I found the files but when i got to the user section, the superadmin i created isnt there. Is it possible to creat a super admin inside this file?
Still that sounds as if your "editing try" wasn't successfull and you do not have any superadmin account anymore ?
The creating should be theoretically possible, but as there is no information on doing this you'd be completly on your own trying to play around with a SQLite "editor". Unless you have very good experience with databases,... I wouldn't recommend to do so.
=> go for the easy solution, if you do not have lot's of accounts to lose, reinitializing the server is WAYS easier and faster !
PS: it's a good idea to creat a backup of database files, especially if they take you a long time to recreate.
More problems with packet loss
By aizauk in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 08-10-2004, 07:44 -
Echo problems on front mic port only.
By Chum in forum [TeamSpeak 2] Client SupportReplies: 6Last Post: 21-09-2004, 03:41 -
win xp + counter-strike problems
By [RIP]Renaldi|UA in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 11-10-2002, 19:51
