Results 1 to 14 of 14
Thread: echo problem
    Feb 2005
    uk
    Unhappy echo problem
    ok iv read the forums on this and there seems to be no clear answer to my problem......
    i have a headset setup, when im on TS with my mates everything i hear gets repeated back to them.... i have tried numerous things even re-installed my pc but with no joy. i have also tried a different sound card but i still get the same problem. i have not had this problem untill i installed newer drivers for my sound, so i used system restore to fix the problem, which worked however im now getting this problem using the original drivers.
    also when i unplug the mic from the pc i still have this problem .... i read somewhere that i should try checking/unchecking the 'what you hear' option but i have not been able to find this. This problem is related to my pc and not others in the TS channel im really out of options to try... please help
    Oct 2004
    England
    alright mate just go into your sound options in control panel and have a play, easy sorted i have to do it everytime i reinstall windows
    Apr 2005
    US
    Quote Originally Posted by Dun
    What does that mean in English? I'm having the same problem.
    Aug 2002
    Switzerland
    8,182
    Quote Originally Posted by wilber
    Quote Originally Posted by amizelle
    check your sound mixer and, especially the "recording" settings. Make sure the micro is the ONLY device beeing enabled.
    Some ugly programs have the behaviour to change the sound settings. Might wanne keep that in mind.
    Mar 2005
    germany
    12
    here fgdgf
    Apr 2005
    US
    Quote Originally Posted by guldi
    I think there is a problem here that goes way deeper than standard sound settings. Thankfully we have great posters like Iron Death with such intelligent responses.
    Aug 2002
    Switzerland
    8,182
    usually not as my personel experience in this forums shows that a larg amount of people is completly swamped when asked to open their sound mixer.
    However, instead of react to quite useless thread of Iron Death, pls check your sound mixer.
    Apr 2005
    Europe
    go to ur volume mixer go to properties and enable microfone ( if not already enabled ) and check mute under the microfone .... u can still speak but without echo
    Apr 2005
    US
    The echo doesn't come from me speaking. The echo comes when somebody else speaks. When they speak my green light comes on and hence, the echo.
    I don't have all of the wonderful settings. I have toyed with the few settings XP gives me to no avail.
    I have ordered a new sound card that my clan leader says will work wonderfully (and increase my fragrate in AA, hehehe). But there should be a way to work around this.
    m&m's Guest
    sounds like your operating system sound mixer has "what you hear" checked so it retransmits all incoming sounds
    Apr 2005
    singapore
    My friend is having the same problem too. How do you solve it?
    Feb 2007
    Mexico
    i solved it turning off the hardware acceleration... worked for me
    Control Panel
    Audio and sound devices (or something like that, can't remember)
    At the first screen, the bottom advanced button
    performance
    Just desaccelerate one or two, whatever it needs
    Jul 2007
    england
    Smile
    hi there
    i had the same problem with the echo and this is how i rectified it
    open your volume control
    click on options
    click on properties
    highlight recording, make sure microphone has tick,then ok
    again make sure the mic is selected with tick, now you will probally find the mic vol on full reduce it to almost nothing (between the bottom 2 marks)
    hopefully that should sort your problem out
    Oct 2007
    Spain
    Lightbulb Echo problem solved!
    Quote Originally Posted by amizelle View Post
    I had the exact same problem I realised that the recording mixer was picking up not just the mic as an input/recording device but also the stereo mixdown (what you hear). That's why everything your mates say gets fed back to them. In fact if you play some music with the stereo mixdown recording enabled people will be able to hear the music you are listening to which I find a cool/anoying feature
    Anyway, to solve your problem try this:
    1. Go to Control Panel
    2. Sounds and Audio Devices
    3. In the volume tab click on advanced and the mixer will pop-up
    4. Click on options and then properties
    5. At the Mixer Device select your audio input device (where you have plugged your microphone)
    6. Tick all the boxes and click OK (microphone, line in, front microphone, rear microphone, stereo mix,... they might be named differently depending on your soundcard)
    7. Now tick the "mute" box in all of them except your mic related inputs (microphone, front microphone, rear microphone, recording control)
    I hope that solved your problem
  1. echo / Cave voices problem
    By marcusm in forum [TeamSpeak 2] Client Support
    Last Post: 30-01-2005, 21:48
  2. Basically another echo problem, but probably a little diffrent than the others..
    By StealthEye in forum [TeamSpeak 2] Client Support
    Last Post: 21-07-2004, 16:41
