Results 1 to 2 of 2
    Mar 2005
    UK
    Question Yet another router based problem
    It seems lots of people have problems with routers and TS servers. And i'm one of them.
    Ok so heres my setup:
    Router
    2 computers wired to the router
    2 wireless
    On one of the wired computers is the TS server.
    Now I set it all up correctly, turned off the software firewall (norton) to make sure, set up port forwarding on my router (Belkin) using a guide I found on portforward.com and then messed around some more and even just plain disabled my routers firewall.
    Yet STILL only people from inside the network can connect. I have had various people try to, most of the time it just says that the server doesn't exsist or isn't running TS, and one time it said that there was a socket error 1140 or something like that.
    Pinging my ip however does get a reply (not sure if this would be the case normally or not just thought anything helps)
    So what else can i do
    Thanks for any help.
    Aug 2002
    Switzerland
    8,182
    1) Have you gone through the FAQ ("no reply" "not all can connect",...) ?
    2) Concerning the socket error, I bet you'll find lot of info by using the search function.
    3) A ping only shows you if the IP interface is answering, but it will not tell you if the portforwarding was setup successfull. A good test is to let your buddies connect to other TS servers. If they are able to connect, the problem lies within your configuration (port forwarding, firewall,...).
  1. Replies: 7
    Last Post: 29-11-2004, 14:33
  2. Netgear FVS318 Firewall Router Problem
    By Mustang51 in forum [TeamSpeak 2] Server Support
    Last Post: 20-07-2004, 10:33
  3. Problem mit Router
    By Gr4veDigg3r in forum [TeamSpeak 2] Client Support
    Last Post: 19-03-2004, 14:28
