Results 1 to 5 of 5
    Mar 2005
    NL
    Installation help please
    Hello all,
    For a reward of 100 us dollar i would like if possible some help with the installation of the teamspeak server script on my Linux Suse server. This because i am a linux noob
    I dont know any other specs the the ones below. I dont know if it can run at all on the server so that should be checked first ?
    I will give you ofcourse shell access to install it
    It is a dedicated server.
    Specs are:
    CPU: 1GHz Pentium3
    RAM: 256MB SDRAM
    HD: 20GB IDE
    OS: Linux SuSE 9.0 + Confixx 3.0
    I prefer someone who is known and trusted on this site
    Also i need after a succesfull installation some help in setting it up the correct way [all the settings]
    payment through paypal
    Aug 2002
    Switzerland
    8,182
    why don't you go through one of these wonderful installation tutorials ? running a server and not really knowing why it runs is not a very good / secure thing. I'd recommend you make yourself a little bit familar with your servers OS and try setting it up yourself (this way you have better chance to fix it later if something goes wrong).
    Beside the spec you post is perfectly ok for running a server. As the server does not mixe voice streams, it uses VERY littl CPU time (but depending on the codec settings,....) quite a few bandwidth which should be hopefully not a problem with a rented ded. server.
    Mar 2005
    NL
    i have a free 1024 GB bandwith per month with that server.
    The ram was wrong b t w...thats 512 Mb
    i did try to set it up....but i am failing. Also with the good tutorials
    Aug 2002
    Switzerland
    8,182
    Quote Originally Posted by mahel
    but i am failing.
    that's not a failure description we can help you with
    Sep 2002
    Louisville Ky
    153
    I would be glad to install it for you for $9.99.
    Or you can go to my tutorial and try it for yourself.
    Tutorial
    For additional help after the installation the price could be more. But $100.00 I am affraid is just too much. Get ahold of me and I will be glad to help you out.
  1. Unattend installation
    By hitmanps69 in forum [TeamSpeak 2] Client Support
    Last Post: 22-12-2004, 04:59
  2. Problem with installation
    By BonelessBoy in forum [TeamSpeak 2] Client Support
    Last Post: 29-06-2004, 03:33
  3. Recompiled installation
    By wesb in forum [TeamSpeak 2] Client Support
    Last Post: 15-06-2004, 15:34
  4. Brauche dringende hilfe zur installation
    By Buddy1710 in forum [TeamSpeak 2] Server Support
    Last Post: 28-01-2003, 07:50
