Results 1 to 8 of 8
    Mar 2005
    New Orleans
    need help teamspeak not working
    i have an error when i try to connect to my teamspeak. any ideas on what could be wrong? anything i can check to make sure its working, or maybe another program i need.
    any help is appreciated
    Dave
    m&m's Guest
    how about posting the error lol you come for help and don't say whats wrong .
    Mar 2005
    New Orleans
    ok the error said that it got a bad response from the server. (in red, in the rectangular box at the bottom of the teamspeak window)
    Dave
    Mar 2005
    BC Canada
    Same Trouble
    Hi
    I too have same problem, have downloaded client twice and reinstalled numerous times. I know it is not a firewall issue as I have a win 98 machine connected to the same router and it works fine. I am using AMD 64 Athlon with Win XP Version 5.1 Build 2600.xpsp2.040919 : Service Pack 1... Is that any help? What should I try next?
    Thanks
    Dave C
    m&m's Guest
    Mar 2005
    BC Canada
    No that did not work, the windows 98 machine is running the exact same version and it is fine. When I try and connect to a specific server I get the red message saying "Got a bad responce from the server" using quick connect. If I try and get a list of servers using just connect, the web server list is blank, and when I try and update the list it says "error getting list".
    does this help any more?
    Dave C
    PS I just installed it on another machine and I noticed that the difference is that the machine that worked installed codecs, the machine that does not work would not intall any codecs, how do I make it install codecs?
    Jul 2004
    Dallas
    113
    Sounds like an evil firewall. Software firewall to be more precise. Do you have Norton Internet Security or anything along those lines? If your positive you have no software firewall bundled with a virus scanner, try putting yourself as DMZ host through your router (this is dangerous as you will not have a firewall)
    Mar 2005
    Ventura,CA
    ts2 problem with echoing
    While using ts2 with nascar 3 I get a voice echo... meaning it will go ... and repat one sound for awhile.... like ah ah ah ah ah ah ah ..... then stop... then again at different times it does the same thin... making it very difficult to hear my other drivers on my team.... any help
  1. Cannot get mic working with Teamspeak
    By Frozen-Solid in forum [TeamSpeak 2] Client Support
    Last Post: 15-11-2004, 01:19
  2. Teamspeak just stopped working?
    By Tyeson in forum [TeamSpeak 2] Server Support
    Last Post: 23-08-2004, 21:22
