Results 1 to 6 of 6
    Mar 2005
    dadsad
    Angry PLEASE Read - Unable to Connect with my LAN Computer!
    Hi, i got a main pc and laptop computer hooked up. My brother uses TS2 with Eve online, and he was able to connect to his CLAN server and chat fine. Untill a few days ago, it keeps saying
    18:59:15] Connecting to 70.84.100.102:8767
    [18:59:15] Got a bad response from the server
    My main comp can connect fine,
    Both comps have EXACT same ver, as i installed latest on laptop, even copied form main to thiscomp and ran, but same thing keeps saying. I have no FIREWALL on this computer other then SP2 which i disabled.
    I REALLY NEED this to be fixed BAD!, any programs or things u know on how to solve this?
    * NOTE * Pinging this server 70.84.100.102:8767, or any TS SERVER give sme 4 lost packets, could nopt find host!
    Oct 2002
    2,594
    which router do you use?
    most probably it doesn't use NAT properly, as you get lost packets... this might be your problem, not the version of the ts-client.
    more info might be in your TSClient.log file... please paste some content of that file, where you have error-messages...
    cu
    SatanClaus
    Mar 2005
    dadsad
    -------------- log started at 27-03-05 19:31 -------------
    27-03-05 19:32:17,1624,ERROR,ProcedureInfo,Client Open,EidSocket: Socket Error # 10065
    No route to host.
    27-03-05 19:34:29,2412,WARNING,All,procedure TDICallBack.execute,"The operation had no effect." or "The device buffer overflowed and some input was lost." or "The device exists but is not currently attached." or "The change in device properties had no effect."
    27-03-05 19:36:26,2412,WARNING,All,procedure TDICallBack.execute,"The operation had no effect." or "The device buffer overflowed and some input was lost." or "The device exists but is not currently attached." or "The change in device properties had no effect."
    27-03-05 19:36:52,2412,WARNING,All,procedure TDICallBack.execute,"The operation had no effect." or "The device buffer overflowed and some input was lost." or "The device exists but is not currently attached." or "The change in device properties had no effect."
    27-03-05 19:40:48,2412,WARNING,All,procedure TDICallBack.execute,"The operation had no effect." or "The device buffer overflowed and some input was lost." or "The device exists but is not currently attached." or "The change in device properties had no effect."
    Man i really hope you can fix this, and what you mean what router.. i dont got a router,, its direct cable to the laptop.
    Mar 2005
    dadsad
    ddsa
    anyone? help plz
    Mar 2005
    dadsad
    /bump anyone come on, you made this program, and you cant help me?!!@!!!
    Oct 2002
    2,594
    as you obviously didn't take your time to search the forum for parts of the error-message the client-log provides... and instead private-messaged me to do it and post you a link... I'd suggest to read the forum-rules
    http://forum.goteamspeak.com/showthr...et+Error+10065
    cu
    SatanClaus
  1. I can find my IP
    By Barmace in forum [TeamSpeak 2] Server Support
    Last Post: 21-05-2005, 12:01
  2. Wireless computer won't connect.
    By thumper8974 in forum [TeamSpeak 2] Client Support
    Last Post: 09-11-2004, 05:51
  3. disconnection
    Last Post: 10-10-2004, 19:23
  4. people unable to connect on wan side
    By spie in forum [TeamSpeak 2] Server Support
    Last Post: 16-05-2004, 04:07
  5. How to connect 2 computers to a third computer (server) when all 3 are on lan?
    By tovlakas in forum [TeamSpeak 2] Server Support
    Last Post: 18-01-2003, 11:10
