Results 1 to 4 of 4
Thread: Help TCPQuery
    May 2005
    Denmark
    Help TCPQuery
    I try to start my server whit TCPQuery=80 but i cant start the server only if i use a TCPQuery = 1100 to 65535.
    i can set the TCPQuery=80 and start in win XP but my ts run on a linux
    i will like to start my server whit TCPQuery=80 can some help me.
    Aug 2002
    Switzerland
    8,182
    a good failure description would included the error you get (server.log,...).
    Any service running on that port allready (http,...) ?
    Jan 2003
    4,140
    A simple fact from history: If you want a program to listen on privileged ports (1 to 1024) that program needs to have root privileges.
    If you create a separate (non-root) user for Teamspeak it is obvious why you can't have the web interface on Port 80.
    Besides, if you already run a Webserver on that Port you wouldn't be able to do so anyways. However you can use header("Location: http://www.mydomain.dom:14535") in PHP or mod_rewrite for Apache to provide redirection.
    May 2005
    Spain
    I also have an error starting the server:
    Error, Either an old instance of teamspeak is still running, or
    an other application is using the tcpquery port!
    Error, Server was not started!
    I've searched into server.log for info, but last logged events don't show anny problem:
    -------------- log started at 18-05-05 20:25 -------------
    18-05-05 20:25:01,ALL,Info,server, Server init initialized
    18-05-05 20:25:01,ALL,Info,server, Server version: 2.0.20.1 Linux
    18-05-05 20:25:02,ALL,Info,server, Starting VirtualServer id:1 with port:8767
    18-05-05 20:25:03,ALL,Info,server, Server init finished
    18-05-05 20:25:03,WARNING,Info,server, TeamSpeak Server daemon activated
    -------------- log started at 24-05-05 23:30 -------------
    24-05-05 23:30:04,ALL,Info,server, Server init initialized
    24-05-05 23:30:04,ALL,Info,server, Server version: 2.0.20.1 Linux
    24-05-05 23:30:04,ALL,Info,server, Starting VirtualServer id:1 with port:8767
    24-05-05 23:30:06,ALL,Info,server, Server init finished
    24-05-05 23:30:06,WARNING,Info,server, TeamSpeak Server daemon activated
    -------------- log started at 25-05-05 19:00 -------------
    25-05-05 19:00:05,ALL,Info,server, Server init initialized
    25-05-05 19:00:05,ALL,Info,server, Server version: 2.0.20.1 Linux
    25-05-05 19:00:05,ALL,Info,server, Starting VirtualServer id:1 with port:8767
    25-05-05 19:00:11,ALL,Info,server, Server init finished
    25-05-05 19:00:12,WARNING,Info,server, TeamSpeak Server daemon activated
    - I've also tried to open other TCP port for TCPquery, and didn't work.
    - I commented that line in server.ini, and didn't work.
    - I deleted the PID at server.pid, and didn't work.
    - Of course, there's no other instance of TSserver running.
    Anyone knows?
    Thx!
  1. passwort setzen per tcpquery
    By ishiprog in forum [TeamSpeak 2] Server Support
    Last Post: 19-11-2004, 22:10
  2. upcoming b50
    By R. Ludwig in forum [TeamSpeak 2] Developer Releases
    Last Post: 21-03-2004, 17:54
  3. pre_b46
    Last Post: 06-01-2004, 17:51
  4. *info* tcpquery commands rc2
    By R. Ludwig in forum [TeamSpeak 2] Server Support
    Last Post: 23-10-2003, 08:50
  5. tcpquery serverset
    By mikihasa in forum [TeamSpeak 2] Server Support
    Last Post: 19-04-2003, 05:23
