Results 1 to 7 of 7
    Jul 2005
    USA
    Mic/headphones problem
    I just got a new mic/headphones... its not a USB, but has pink and green plugs on the end, i plug the pink, into the pink slot on the back of my PC, but the green slot was already taken by my speakers. So i plugged the green plug from my mic into the blue slot inbetween the pink and green ones. Now my mic works fine, but i cant make sound come threw my head phones. i hear threw my speakers, but i would rather use headphones. shouldi just switch to green plug with my speaker? Sounds confusing but TY for ur help.
    Jul 2005
    UK
    Yeah try that.
    Jul 2005
    USA
    ok, i tried switching the headset plug with the speaker plug, now everything come out the headphones. i just want the voices on TS to come threw the headset, and the headset isnt showing in the INPUT/OUTPUT options menu
    Jul 2005
    UK
    I'm having a similar problem i think.
    my 5.1 sound is set up correctly. I even have space for my headphone and mic which just leaves the blue line in. (redundant)
    Problem is, all sound is spread across all speakers including headphones. What i want is TS sound through my headphones and all other sound through my main setup.
    Any clues without having to resort to using anothe sound card?
    m&m's Guest
    you need a onbaord sound card and a pci sloted sound card to do that
    set your good sound card to the 5.1 for games and such and use the onboard for teamspeak , select the onboard in the ts settings tab , this will give you seperate sound for ts and games , no mixing
    Jul 2005
    UK
    thanks for the input
    Jul 2005
    Los Angeles
    Yeah with only 1 soudn card, unless it has multiple of the same ports, you can not have just some sound come through your headphones. listen to what MM said.
  1. echo problem
    By wilber in forum [TeamSpeak 2] Client Support
    Last Post: 13-09-2013, 14:57
  2. Problem: Höre nach ca. 20-30min niemanden mehr im TS2
    By LOC-MAXX in forum [TeamSpeak 2] Client Support
    Last Post: 02-07-2003, 16:49
  3. AUDIGY 2 & TS weird very (!) annoying problem!!!
    By doc.pepper in forum [TeamSpeak 2] Client Support
    Last Post: 30-04-2003, 18:06
  4. Bizarre Choppy Problem
    By AngusHeaf in forum [TeamSpeak Classic] General Questions
    Last Post: 03-07-2002, 09:11
