Results 1 to 4 of 4
Thread: Problems
06-10-2005, 20:56 #1
-= TeamSpeak User =-
- Oct 2005
- Location
- Brazil
- 3
Problems
Says "[16:54:39] No reply from server
Maybe the server is offline
or maybe teamspeak is not running on it
I turned off firewall, and tried to forward ports on my router.
Can someone give a step by step, in english, sort of like for dummies setting up the freaknig server.
I use Parkervision WR1500 BTW, sorry don't ban me!
06-10-2005, 20:58 #2
- Oct 2005
- Location
- Brazil
- 3
I can connect by using my comp ip address, but not my online address.
06-10-2005, 22:34 #3
- Oct 2005
- Location
- Brazil
- 3
Got all the right ports open on firewall and on router.
( i use a laptop, on a wireless? maybe this helps)
07-10-2005, 23:33 #4
- Oct 2005
- Location
- USA
- 25
That error seems to mean your packets aren't getting there. so I would blame your router or your firewall.
Originally Posted by Bleh123
Here's a post on setting up the router:
http://forum.goteamspeak.com/showthread.php?t=15092
Also you may want to assign a static IP to your server to prevent some port forwarding related isuues:
http://forum.goteamspeak.com/showthread.php?t=26315
http://forum.goteamspeak.com/showthr...2&page=2&pp=15
You could also just plug your server directly into your outside conection witout a router or anything and test your connection, then add one piece at a time, retesting each time, to make sure everything is working and to narrow down what isn't. I would double and triple check your port forwarding settings before you even try this since it would take quite some time.
Remeber to use http://ts2test.planetteamspeak.com/ to test.
More problems with packet loss
By aizauk in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 08-10-2004, 07:44 -
Echo problems on front mic port only.
By Chum in forum [TeamSpeak 2] Client SupportReplies: 6Last Post: 21-09-2004, 03:41 -
win xp + counter-strike problems
By [RIP]Renaldi|UA in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 11-10-2002, 19:51
