Results 1 to 5 of 5
05-02-2006, 22:36 #1
-= TeamSpeak User =-
- Feb 2006
- Location
- Sweden
- 2
Some clients not being able to connect
I've been using the TS server for a while without any significant problems, but lately there's been popping up the same error again and again, and I can't figure out why.
Originally Posted by server.log
Now, it looks like to me that the session is getting a tiemout, and every time they try to connect they get disconnected 2 second later. This has only happened to a handfull of people and most are able to log onto the server.
Originally Posted by client.log
However, the weirdest part is that some fo those who're not able to join the server has actually managed to get on once! He don't have a static IP and is sitting behind a firewall that hes not able configure by himself, but he never has any problems with other servers, and as I mentioned, he's been able to join before.
I'm all lost on this and I think I'll soon go crazy if I can't fix this problem. I've tried checking the forum and the FAQ, but I haven't been able to find any answers. Please help me! I'll eat a cookie in memorial of you if you can help me.
06-02-2006, 15:50 #2
-= TeamSpeak Guru =-
- Aug 2002
- Location
- Switzerland
- 8,182
checked that one as well: http://forum.goteamspeak.com/showthread.php?t=19293 hthere is soem help on timeout
There's another FAQ dealign with "not all can conenct" suggestign to bind your server to it's IP, tested that (I assume, since you said you read the FAQ's
06-02-2006, 19:06 #3
- Feb 2006
- Location
- Sweden
- 2
I've tried the solutions mentioned in the thread you linked to me (I had actually done that before read it even :P) and it still doesn't seem to be working.
I can't find the other FAQ you're mentioning though dealing with "not all can connect" though, and I've looked through all of the ones who seems to be relevant. Could you perhaps post the link here?
06-02-2006, 21:09 #4
- Feb 2006
- Location
- wi
- 4
kroax im in the same boat as you only im trying to conn and ive tried all that i can see my post http://forum.goteamspeak.com/showthread.php?t=28766 let me know if this is whats happening to ppl trying to connect to your serv or if you find a fix.
07-02-2006, 09:54 #5
- Aug 2002
- Location
- Switzerland
- 8,182
http://www.goteamspeak.com/index.php...=4&item=41#q41
and see as wel lhere if the debug mode does not help. To be honest, when running a server on home connections (DSL, cable) we've encountered from time to time timeouts with certain people. Sometimes the debug mode did help, sometimes an older client version helped. Since we run the server at an ISP, no more timeouts.
Two Clients can't connect at the same time.
By PGerringer in forum [TeamSpeak 2] Client SupportReplies: 4Last Post: 29-01-2006, 01:30 -
Why can some clients connect and others can't?
By trmentry in forum [TeamSpeak 2] Server SupportReplies: 6Last Post: 15-08-2005, 23:11 -
Some clients get connected others connect and immediately timeout
By therealmaximus in forum [TeamSpeak 2] Server SupportReplies: 4Last Post: 28-06-2005, 18:18 -
ant suggestions on how to get clients to connect to my server
By razorback in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 22-03-2003, 09:47
