Results 1 to 5 of 5
Thread: OpenBSD - Lockup issue
25-03-2006, 20:29 #1
-= TeamSpeak User =-
- Mar 2006
- Location
- CHI
- 2
Fresh install on openbsd 3.8. Extracted the packages, set permissions, everything started up perfectly. Connected to the server and the admin site.
Server stops responding after about 3-5 minutes, timing out the client and web interface pages.
Restart the server:
Then it works for a few min then does the same thing over again.
superadmin accounts and passwords when it is ran the first time, I cant log in as superadmin, only admin.
Ideas?Last edited by phong; 25-03-2006 at 20:51.
01-04-2006, 18:27 #2
- Mar 2006
- Location
- CHI
- 2
aw
no comments at all?
10-05-2006, 04:37 #3
- May 2006
- Location
- Canada
- 3
I am experiencing the same issue. I have a default install of OpenBSD 3.8 (no X) I enabled the linux binaries emulation, installed the redhat base, and edited the startscript to point to ksh instead of bash. The webadmin does not respond and users get punted in about 5 minutes.
Originally Posted by phong
I would appriciate any suggestions too.
thanks
30-11-2006, 20:29 #4
- May 2006
- Location
- Canada
- 3
Recently I 've tried to start a TS server running under linux emulation (again) but this time I am using OpenBSD 4.0 and re-read through the compat_linux man page.
- Performed a clean installation of OpenBSD 4.0 (just the base no X).
- sudo sysctl kern.emul.liunx=1 (pkg_add also does this when installed redhat_base...)
- uncommented the kern.emul. line in the rc.conf (for when the server is rebooted.. if ever required)
- downloaded/extracted the tss_rc2 bzip/tarball
- edited the teamspeak_start... script to point to /bin/ksh as I don't have bash installed
- unpacked the same tss2 on a clean debian box to run the ldd command and copied the libs to my OpenBSD box.
- ran the script to start the server then ran it again with the password option to awk the log (shortcut to view superadmin/admin passwords)
- connected to the server via a windows client
After less than 10 minutes the client is disconnected. the status script says "the server appears to be running"
'top' shows the processes are increasing in memory consumption and clients cannot log in to the ts server.
edit: the webadmin does not respond at all.Last edited by dualcells; 30-11-2006 at 20:31. Reason: additional info
09-12-2006, 05:35 #5
-= TeamSpeak Addict =-
- Jun 2003
- 246
you have any logs showing what happens before the freeze?
Sound Issue
By Feyrin in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 24-03-2006, 17:00 -
Americas Army and TS2 stuttering issue..
By ~ghostlywalker in forum [TeamSpeak 2] Client SupportReplies: 7Last Post: 27-12-2005, 22:32 -
How do I make it work under OpenBSD?
By kleptophobiac in forum [TeamSpeak 2] Server SupportReplies: 4Last Post: 28-10-2003, 08:15 -
TS Locks up. Please Help
By merlin937 in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 24-09-2003, 05:39 -
Whisper to channels issue with GV hardware
By Moonmagi in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 05-12-2002, 15:32
