Results 1 to 2 of 2
Thread: help
21-05-2006, 12:19 #1
-= TeamSpeak User =-
- May 2006
- Location
- d
- 2
help
hey i setup my sever i did the thing in my sever.ini i added hte ip that was 124.177.136.82 and my mate cant login to it yet what have i done wrong?and i cant even get on with out logging in to 10.0.0.1
22-05-2006, 14:43 #2
-= TeamSpeak Guru =-
- Aug 2002
- Location
- Switzerland
- 8,182
1) binding a server to the WAN IP is only needed if you have serveral IP interfaces installed (which most home users do not have)
2) connecting to your WAN IP from within the LAN is a bad idea and will usually only lead to a lot of problems as most users do have cheap home access devices (routers,...) and hey do not suport that => don't do that, from within the LAN, only use the LAN IP
3) you might miss a port forwarding as stated in the FAQ (by the way, that is our standard answer we are luckily allowed to give almost each day between 10 - 20 times as most users do not read FAQ's,... => if oyu wanne know more, do a forum search)
