Results 1 to 2 of 2
    ecfulle Guest
    Help pls ... server on RedHat 8.0
    Hi everyone... I'm running two machines. One with Xp and the other with RH Linux 8.0. They are behind a linksys router. I use DMZ hosting function to forward my IP to the XP or RH box depending on how I need things...
    Having said that I can host t/s server on the XP box (dmz forwarding my external address to the XP box) perfectly fine with my friends able to connect.
    I can successfully start, configure, stop, etc. t/s server on the RH box just fine. And from the XP box I can connect my linux box by putting in the external ip like others would (when dmz forwarding my external address to the RH box). Others cannot. I can't figure out why. As best I can tell t/s uses port 14534 for the admin configuration. But for others to connect it uses port 8767. Is this correct? Why can I connect and others can't?
    I want to host t/s server on the Linux machine.
    Thanks,
    Erik
    Jun 2002
    Netherlands
    1,198
    Servers need to be available. So you need to forward port 8767 udp and the web tcp port to your server on your router.
    The clients dont need portforwarding
  1. »»» FAQ - TS 2.x Server
    By Michael in forum [TeamSpeak 2] Server Support
    Last Post: 29-12-2009, 23:20
  2. Cannot connect to server by LAN or WAN
    By Basti504 in forum [TeamSpeak 2] Server Support
    Last Post: 25-11-2007, 22:30
  3. Can't enter admistration or my server.
    By TheSavior in forum [TeamSpeak 2] Server Support
    Last Post: 10-06-2006, 22:48
  4. disconnection
    By Barmace in forum [TeamSpeak 2] Server Support
    Last Post: 10-10-2004, 19:23
  5. RC2 Server Crashing For No Reason
    By Aww You Dead in forum [TeamSpeak 2] Server Support
    Last Post: 08-03-2003, 00:49
