Results 1 to 3 of 3
18-08-2006, 02:26 #1Minerva7 Guest
TS window doesn't appear on start
About half the time when I try to start TS, no window appears. Task manager shows it running, using ~10k of memory, 13 threads, but no window. Ending the process only reduces it to 1 thread that won't go away. This is only fixed with restarting the machine- logging out doesn't do it.
When it does work, it skips right past 13 threads and 10k memory usage and everything is normal. But it's entirely unpredictable as to whether it works or not on any given reboot. Tried killing other processes, but has had no effect either way.
So is there a fix or workaround for this?
18-08-2006, 10:24 #2
-= TeamSpeak Addict =-
- Jun 2002
- 704
might be a driver problem. Try updating your sounddrivers.
If that doesn't help, try to change a few settings in Teamspeak (choose either "direct sound" or "wave").
If that doesn't help either, try to do a clean uninstall and reinstall (get rid of the "hidden" configuration file -> refer to FAQ for location)
Still the same problem? Post here again with some more details please.
18-08-2006, 11:56 #3Bastian Guest
When we are talking about giving more information, please read our forum rules to learn which information we need.
Auto Start :: Windows 2003 SBS
By linsys in forum [TeamSpeak 2] Server SupportReplies: 9Last Post: 21-06-2006, 19:26 -
Start stop script for TeamSpeak daemon (init)
By Cybernaut in forum [TeamSpeak 2] Server SupportReplies: 2Last Post: 11-11-2004, 17:07 -
Suggestion: add a menu option to keep the teamspeak window always on top
By Scamper in forum [TeamSpeak 2] General QuestionsReplies: 1Last Post: 24-06-2003, 01:59 -
Start script..
By NitroSniper in forum [TeamSpeak 2] Addons & ScriptsReplies: 3Last Post: 27-08-2002, 07:12
