Results 1 to 4 of 4
    Sep 2006
    United Kingdom
    Weird Log In Admin Problem
    Hello there, i have installed the server and got the passwords from the original setup, i logged in the admin section via the web, i then closed the server and restarted it and now i cant log into the admin section. at all, i made sure cookies were on and have tried different browsers.
    So then i un intaleld and re-installed and got a set of new passwords, and again i could log in fine so this time i changed the password and i delted the character thing out of the server.ini fille to allow characters such as [] () and re started the server. And again i cannot log into the admin part via the web.
    This only seems to happen when i restart the server. Any ideas lol cuz this has got me dumb founded and sorry if this has been adressed before i did try searching but couldnt find anything.
    Thanks in adavanced
    Sep 2006
    California
    8
    I've got the same problem, but it was after I edited the server.ini file to add the BoundToIP1 IP address.
    Sep 2006
    California
    8
    Nevermind, I got it fixed, I reverted the server.ini file back to what it was and followed the instructions about opening the port addresses and it works fine!!! Try reverting the server.ini file back to the original because it might be a possibility that TS Server program noticed that the server.ini file doesn't look right and isn't loading all the way.
    Jul 2006
    US
    11
    This happens to be when I change the BoundToIP field, too. When I right click on the server icon the administration area is greyed out. I also cannot connect to the server when I do this too. I checked and rechecked to make sure I had the IP correct and it was. It always worked before until recently.
  1. cant log into client using admin username and password
    By pleco in forum [TeamSpeak 2] Client Support
    Last Post: 20-07-2006, 19:23
  2. I cant log in as admin on my server
    By popsmight in forum [TeamSpeak 2] Server Support
    Last Post: 13-07-2006, 16:11
  3. Two problems, what to do? No admin, and how do i log on?
    By Xale in forum [TeamSpeak 2] Server Support
    Last Post: 07-06-2005, 08:27
  4. Weird server problem
    By BlackKnight35 in forum [TeamSpeak 2] Server Support
    Last Post: 05-10-2004, 04:14
  5. Problem Logging In to Server Admin Page
    By DaTomi in forum [TeamSpeak 2] Client Support
    Last Post: 16-01-2003, 19:44
