Results 1 to 10 of 10
01-03-2007, 01:37 #1
-= TeamSpeak User =-
- Mar 2007
- Location
- usa
- 1
audio problemas on compaq presario SR1913WM
my friend its using the team speak on compaq presario SR1913WM and he cant setup the audio right,always when i talk to him my voice come back to me evem if he remove the head set from computer ,we checked the drivers ,codecs,we put main volume up and down and nothing,we also checked other programas to talk and it happens only in team speak.any idea???
01-03-2007, 02:15 #2
-= Undercover TeamSpeak Fanatic =-
- Jan 2007
- Location
- LA
- 4,700
Aww. I got another post around here with what is going on. If I can find it I will copy it, I do not want to type it again.
Edit: found it.
Start>Control Panel>Sounds and Audio Controls>Advanced>Options>Propertes>Recording(Make sure all boxes are ticked)>OK>Tick the One for microphone.
You most likely have sound out or "What you hear" option as the recording device. I use it sometimes as a way to stream music across TS.
EDIT AGAIN:
Since I use this thread a lot for audio, and some in vista. Going to add how to access from vista.
For mic control:
Start>Control Panel>Sounds>Recording>Right click>show disabled devices>double click or right click properties on the microphone>Level controls the volume that other people can hear you>Custom is for mic boost, used if level control can not get your voice high enough for others to hear you.
For playing music:
Start>Control Panel>Sounds>Recording>Right click>show disabled devices>Chose the "what you hear" or stereo mix, whatever it is called on your machine.Last edited by BHKai; 12-03-2008 at 16:43.
30-11-2007, 07:08 #3
- Nov 2007
- Location
- Mass
- 2
Thank you very much, i feel like a jack*** now but you were right lol. Thanks for the help!
17-05-2008, 19:53 #4
- May 2008
- Location
- South Africa
- 1
cant select michrophone option in recording control
it seems to be stuck on stereo mix and wont select microphone check box
17-05-2008, 21:20 #5
- Jan 2007
- Location
- LA
- 4,700
Try updating your drivers.
Vista or XP?
24-05-2008, 04:16 #6
- May 2008
- Location
- Colorado Springs
- 1
This didn't help and i still have the same problem. I'm using a Dell Dimension 4550 with onboard Soundmax and just repeats this like wind tunnel noise over and over in local test, havn't tried it in regular chat yet
24-05-2008, 05:12 #7
- Jan 2007
- Location
- LA
- 4,700
It is not my fault your are an idiot.
If your mic picks up what your speaker plays and plays that through your speakers and the loop continues. It will make that high pitched sound. Use quality headset and you would not have such a problem.
You can not say that what I posted is not the solution. That problem is only caused by you having the wrong settings where the mic is played through the speakers.
22-06-2008, 23:26 #8
- Jun 2008
- Location
- spain
- 1
I have a similar problem but is very strange because, i disable the wave (mute) and still the mic is reproducing ,for example im listening a song In teamspeak and i put it in voice activation, i disable the wave i dont listen nothing but the mic reproduce a bucle of the song... i need help, the problem appear when i change the Motherboard, i have try with drivers of Realtek (builder of the audio integrated) and nvidia (motherboard) and none works.
23-06-2008, 02:30 #9
- Jan 2007
- Location
- LA
- 4,700
Why wave?
Mute the mic in playback and make sure that the mic is the only thing selected in the recording panel. Your audio card might have it's own sound control panel.
07-12-2008, 21:30 #10
- Jul 2008
- Location
- Wa state USA
- 2
you sir are a godsend, you just made my TS a ton better. now my corpm8ts can listion to me spin!!
Question: How can I split audio sources?
By Gazz in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 08-05-2005, 00:07 -
Problem gleichzeitig sprechen zu können und die Leute zu hören
By Kaot in forum [TeamSpeak 2] Client SupportReplies: 0Last Post: 26-11-2004, 23:52 -
TS is very slow under Windows 98 on a Compaq Presario
By SoCalScannerNut in forum [TeamSpeak 2] Client SupportReplies: 6Last Post: 02-11-2003, 09:07 -
Better Audio codecs
By Manure in forum [TeamSpeak 2] General QuestionsReplies: 6Last Post: 07-09-2003, 11:13
