Results 1 to 4 of 4
Thread: I am stuck please help
17-03-2007, 20:07 #1
-= TeamSpeak User =-
- Oct 2006
- Location
- temple,nh
- 9
hey every1 my server is having problems with connecting. I can connect through localhost but cant connect otherwise. Yes i am using a router and i did the forwarding idk if i did it right but i think i did it right. i went to the http://ts2test.planetteamspeak.com site that i saw when some1 else was having this problem and it showed everything with a circle and an x in the middle. that obvioulsly means something wrong but idk wat. please help me.
17-03-2007, 22:24 #2
-= Undercover TeamSpeak Fanatic =-
- Jan 2007
- Location
- LA
- 4,700
You have to make an exception in you firewall. If that does not fix the problem could you please post a screenshot of your port forwarding settings.
17-03-2007, 23:02 #3
- Oct 2006
- Location
- temple,nh
- 9
do you have any suggestions on what to exept or should i just turn firewall off? the model is LINKSYS WRT54GS if that helps any.
18-03-2007, 00:57 #4
- Jan 2007
- Location
- LA
- 4,700
Make an exception for UDP port 8767.
Your port forwarding settings should look like this except different IP.
http://img62.imageshack.us/img62/118...outing2yh9.png
Stuck on Mute
By ShinRa Inc in forum [TeamSpeak 2] Client SupportReplies: 4Last Post: 24-01-2007, 19:32 -
Voice Activation stuck on
By 6feet_ in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 21-11-2006, 04:57
