Results 1 to 8 of 8
02-07-2007, 23:23 #1
-= TeamSpeak User =-
- May 2005
- Location
- New Jersey
- 26
Weird problem regarding my server
Ok I fowarded all my proper ports and gave ts server and client access through my firewalls. However I nor any of my friends cannot access my server. Now i know this has been asked before but here is the weird part i recently installed it about a week ago and used it 3 times the first time i had the wrong number for the computer ie 192.168.1.100 / 192.168.1.101 but that was my fault then it was working after i fixed it. The second time we tried to use it next day it did not work again ( i noticed my computer now switched overnight from 101 to 100 ( i didnt know it did it whenever it wanted to ) but i fixed that a 2nd time. now is the 3rd time i am still computer 100 all ports forward firewalls still alow TS to access the net and my IP has been the same everytime but my friends today cannot connect neither can I what can i do this time to fix it?
02-07-2007, 23:32 #2
-= Undercover TeamSpeak Fanatic =-
- Jan 2007
- Location
- LA
- 4,700
Give the server a stat ip, dhcp if your router has it. Makes sure that the port forwarding rules are correct as you go a new lan ip.
What firewall do you have?
02-07-2007, 23:34 #3
- May 2005
- Location
- New Jersey
- 26
I closed out of server and Client and restarted both and it now works. Don't know what the problem was I didnt change a thing.
02-07-2007, 23:57 #4
- Jan 2007
- Location
- LA
- 4,700
Make sure to give the server a static to stop some of the problems that can occur.
08-07-2007, 02:57 #5
- May 2005
- Location
- New Jersey
- 26
ok so for the life of me i cannot figure this out i need to keep trying to connect to my server after numerous times it will eventually work. But I do not make any changes just quick connect make sure my info is correct then click join and repeat until it connects. any ideas? after a few times eventually iy lets me connect
08-07-2007, 03:04 #6
- Jan 2007
- Location
- LA
- 4,700
08-07-2007, 03:28 #7
- May 2005
- Location
- New Jersey
- 26
Porblem Fixed?
Porblem Fixed?
Turns out I read somewhere that you need to Forward Port 8767 TCP as well as UDP. I only had UDP which I have only done in the past and seemed fine. Now it turns out i need it forarded on both for some reason so far i am 3-3 with both forwarded
08-07-2007, 07:20 #8
- Jan 2007
- Location
- LA
- 4,700
Server stops responding
By Xeroed in forum [TeamSpeak 2] Server SupportReplies: 10Last Post: 27-09-2006, 04:08 -
Can't enter admistration or my server.
By TheSavior in forum [TeamSpeak 2] Server SupportReplies: 12Last Post: 10-06-2006, 22:48 -
Scheisse habe QDSL alles geht nur keine REG
By Creeper in forum [TeamSpeak 2] Server SupportReplies: 6Last Post: 29-08-2002, 09:06
