Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: ts problem
    Jul 2007
    germany
    8
    ts problem
    Hi habe ein ts problem und kann diese nicht beheben. Der vserver von 1blue ist stabiel aber der ts fährt runter und fährt wieder hoch. und des mindestens alle 30 min oder so.
    Hier mal ein paar server logs die ich net so recht verstehe. (bin ein neuling in sachen linux und ts - nur mal zur info). Bitte um ein lösung
    -------------- log started at 08-07-07 18:05 -------------
    08-07-07 18:05:09,ALL,Info,server, Server init initialized
    08-07-07 18:05:09,ALL,Info,server, Server version: 2.0.23.15 Linux
    08-07-07 18:05:09,ALL,Info,server, Starting VirtualServer id:1 with port:1001
    08-07-07 18:05:09,ERROR,All,SERVER, VirtualServer startup failed with port 1001, Exception: EIdSocketError.Socket Error # 13 Access denied.
    08-07-07 18:05:12,ALL,Info,server, Starting VirtualServer id:2 with port:1002
    08-07-07 18:05:12,ERROR,All,SERVER, VirtualServer startup failed with port 1002, Exception: EIdSocketError.Socket Error # 13 Access denied.
    --------------- log ended at 08-07-07 18:05 --------------
    08-07-07 18:05:28,ALL,Info,server, Server init finished
    08-07-07 18:05:28,WARNING,Info,server, TeamSpeak Server daemon activated
    08-07-07 18:19:41,ERROR,All,SQL ExcecSQL Error: unable to open database file in query: update ts2_clients set dt_client_lastonline = '08072007181941932'where i_client_id = 4; 08-07-07 18:19:41,ERROR,All,WEBINTERFACE, Progress_COMMAND Exception: EInvalidField.DatabaseError: unable to open database file
    -------------- log started at 08-07-07 18:21 -------------
    08-07-07 18:21:08,ALL,Info,server, Server init initialized
    08-07-07 18:21:08,ALL,Info,server, Server version: 2.0.20.1 Linux
    08-07-07 18:21:09,ALL,Info,server, Starting VirtualServer id:1 with port:1001
    08-07-07 18:21:09,ALL,Info,server, Starting VirtualServer id:2 with port:1002
    --------------- log ended at 08-07-07 18:21 --------------
    08-07-07 18:21:23,ALL,Info,server, Server init finished
    08-07-07 18:21:23,WARNING,Info,server, TeamSpeak Server daemon activated
    08-07-07 18:22:14,ALL,Info,server, Server shutdown initialized
    08-07-07 18:22:17,ALL,Info,server, Server shutdown finished
    --------------- log ended at 08-07-07 18:22 --------------
    -------------- log started at 08-07-07 18:24 -------------
    08-07-07 18:24:22,ALL,Info,server, Server init initialized
    08-07-07 18:24:22,ALL,Info,server, Server version: 2.0.23.15 Linux
    08-07-07 18:24:23,ERROR,All,SQL, ExcecSQL Error: unable to open database file in query: PRAGMA default_synchronous = OFF;
    08-07-07 18:24:23,ERROR,All,SERVER, Start_Server: unable to open database
    --------------- log ended at 08-07-07 18:24 --------------
    08-07-07 18:26:21,ALL,Info,server, Server init finished
    08-07-07 18:26:21,WARNING,Info,server, TeamSpeak Server daemon activated
    08-07-07 18:26:24,ALL,Info,server, Server shutdown initialized
    08-07-07 18:26:24,ALL,Info,server, Stopping VirtualServer id:2 with port:1002
    08-07-07 18:26:25,ALL,Info,server, Stopped VirtualServer id:2 with port:1002
    08-07-07 18:26:25,ALL,Info,server, Stopping VirtualServer id:1 with port:1001
    08-07-07 18:26:25,ALL,Info,server, Stopped VirtualServer id:1 with port:1001
    08-07-07 18:26:27,ALL,Info,server, Server shutdown finished
    --------------- log ended at 08-07-07 18:26 --------------
    Dec 2006
    Germany, Bay, Würzburg,...
    3,158
    lösche mal die datei server.dbs (achtung: dabei gehen alle server und user verloren) und starte dann den server nochmal neu.
    außerdem solltest du programme NIEMALS unter root starten, es sei denn diese benötigen root rechte. teamspeak tut das aber nicht!
    am besten installierst du den server nochmal komplett neu. es gibt hier tutorials, wie man einen ts server auf einem linux rootserver installiert. einfach mal danach suchen.
    Jul 2007
    germany
    8
    ok danke werd ich mal schauen
    Jul 2007
    germany
    8
    hook nun habe ich es wie du es gemeint hast gemacht aber nun kommt immer dieses befehl und der ts startet niht mit dem neuen user:
    ts@v29675:~/tss2_rc2> server_linux
    Warning, We found an already existing PID file, which will be overwritten
    Error starting daemon. Aborted
    ts@v29675:~/tss2_rc2> ./teamspeak2-server_startscript start
    starting the teamspeak2 server
    Dec 2006
    3,158
    Quote Originally Posted by Averlome View Post
    hmm..... diese befehle gibst doch du ein
    und wie meinst du das mit neuem user starten?
    wenn die fehlermeldung
    auftaucht, macht das eigentlich ncihts, der server sollte trotzdem laufen. poste doch mal die letzten zeilen der server.log datei
    Jul 2007
    germany
    8
    ja der server startet der TS läuft aber nun kommt das ABER
    Das dumme TS fährt alle 30 - 40 minuten runter und der ssh macht auch nen kleinen pause mindestens 10 - 20 sec danach läuft ts wieder und mann kann auch ssh nutzen.
    Aber kenne viele TS-Server die bei 1blue sind und die haben nicht solche ausfälle.
    Dec 2006
    3,158
    d.h. du kannst während der ts down ist auch nicht auf den server zugreifen? dann wird es wohl ein problem des rootservers sein und nicht vom teamspeakserver!
    Jul 2007
    germany
    8
    dachte ich mir auch aber auf dem selben server ist meine web seite die geht und ein bot läuft der ist auch constand dabei nur ts fält kurtz aus und ist wieder erreichbar.
    Dec 2006
    3,158
    evtl. merkt der bot garnicht, wenn die verbindung kurz abreißt. schonmal daran gedacht?
    Jul 2007
    germany
    8
    dann wär in dem moment aber die web seite down
    Dec 2006
    3,158
    frag einfach mal beim provider nach. die können dir evtl. mehr auskunft geben
    Jul 2007
    germany
    8
    verdammt die sagen es sei alles in ordnung es muss am ts dieses problem liegen
    Sehr geehrter Herr XXXXX,
    vielen Dank fuer Ihre Anfrage.
    Wir haben Ihre Support-Anfrage geprüft und konnten keine Einschränkungen
    feststellen.
    Um Ihnen einen optimalen Kundenservice garantieren zu
    können, bitten wir Sie die Funktionalität noch einmal zu überprüfen.
    Gerne stehen wir Ihnen für weitere Fragen zur
    Verfügung.
    Mit freundlichen Grüßen aus Berlin,
    Ihr 1blu Support-Team
    Dec 2006
    3,158
    -> nicht nur der ts server ist nicht erreichbar.......
    dass teamspeak rootserver lahm legt, kann ich mir nicht vorstellen
    Nov 2002
    Germany / Kempen
    1,844
    Ich würde an deiner Stelle einfach mal den Server und dessen Anbindung überprüfen. Beispielsweise mit mtr.
    Jul 2007
    germany
    8
    Also ich habe die log files angesehen der server zeigt keinen ausfall verbindung in ms sind 25 - 120 ms je nach dem was ich uploade und downloade. ich vermute es liegt eventuel am ssh einstellungen des servers. ( Bin in der hinsicht total der nup. ) bei interesse hier mal die TS daten. könnt ja mal vorbei schauen.
    Serverip: averlome.de:1001
    PW: GR
  1. echo problem
    By wilber in forum [TeamSpeak 2] Client Support
    Last Post: 06-10-2007, 02:09
  2. CS Problem!
    By crem in forum [TeamSpeak 2] Client Support
    Last Post: 01-09-2002, 13:22
