Results 1 to 4 of 4
Thread: Ts2Perl mod problem
31-07-2007, 21:11 #1
-= TeamSpeak User =-
- Jul 2007
- Location
- germany
- 18
Ts2Perl mod problem
hello guys,
well, I tried to start the perl mod with my own computer with windows xp.
But if I try to start the script by opening the "ts2perlmod.pl" I get this :
whats the problem? If I try the the connection test from tsplanet:Code:TS2PerlMod GNU/GPL-Edition [Version 0.9.16] Copyright (c) 2005, 2006 by Sven 'ScP' Paulsen [ok] Using configuration file default.ini Use of uninitialized value in socket at C:/Perl/lib/IO/Socket.pm line 80 (#1) (W uninitialized) An undefined value was used as if it were already defined. It was interpreted as a "" or a 0, but maybe it was a mistake. To suppress this warning assign a defined value to your variables. To help you figure out what was undefined, perl tells you what operation you used the undefined value in. Note, however, that perl optimizes your program and the operation displayed in the warning may not necessarily appear literally in your program. For example, "that $foo" is usually optimized into "that " . $foo, and the warning will refer to the concatenation (.) operator, even though there is no . in your program. [!!] Could not establish connection to server 127.0.0.1 Press return key to exit...
http://ts2test.planetteamspeak.com/?page=step1
But it shoes green lights!
My ssa account does have only 4 letters btw.
I hope you guys can help me out!
(I already posted this in another section, but I think I was wrong xD)
31-07-2007, 22:08 #2
- Jul 2007
- Location
- germany
- 18
So, I tried it on the PC form my parents, it's working there!
I used teh exactly same folder, but why is it working there and not here??
01-08-2007, 01:37 #3
-= Undercover TeamSpeak Fanatic =-
- Jan 2007
- Location
- LA
- 4,700
Maybe your computer does not allow it to connect to itself. Which firewall do you have?
01-08-2007, 02:00 #4
- Jul 2007
- Location
- germany
- 18
I have no firewall.
But I know why it didn't work,
A while back I deleted my c./windows/system32/etc/ folder.
I got it now, please delete this thread!
echo problem
By wilber in forum [TeamSpeak 2] Client SupportReplies: 13Last Post: 06-10-2007, 02:09
