Results 1 to 6 of 6
Thread: help me
24-11-2007, 22:08 #1
-= TeamSpeak User =-
- Nov 2007
- Location
- USA
- 3
help me
i know this has been posted before but i can't quite understand it.
how do i get my dyndns account as the server ip so i don't have to use my ip that changes when ever it feels like it.....
also explain it to me like i was a complete and total idiot!
because i am almost there
25-11-2007, 01:04 #2
-= Undercover TeamSpeak Fanatic =-
- Jan 2007
- Location
- LA
- 4,700
http://www.dyndns.com/support/clients/
To keep the dns pointing to the right ip.
Then just use the dns name with the port number, if you are not using the default port.
25-11-2007, 20:14 #3
- Nov 2007
- Location
- USA
- 3
still not the answer i want
how do i make it so that the address you connect to is (my server name here)
26-11-2007, 00:41 #4
- Jan 2007
- Location
- LA
- 4,700
Is The Answer You Want!
I am sorry to tell you but you are going to have to read one of the links that I post you.
http://www.dyndns.com/support/kb/how_ddns_works.html
At the bottom it says how to get started:
Create account
Choose name:
Point to ip: Either hardware or the client I posted earlier. <<== Step you seem to be at. A.K.A. My last post.
Use it now. (ex. ts.thejungle.us:1010 works and 69.11.176.19:1010 is the same address.) or if you use the udp port 8767 then all you have to use is just your dns name. (ex. thejungle.us )
27-11-2007, 01:10 #5
- Nov 2007
- Location
- USA
- 3
ty anyways
well ty anyways you did help a little bit but not at all really you forgot to add one part the fact that i needed to add my dns to the hosts file i remembered it from another guide for something similar but different ty for your help(somewhat) lol and nice server by the way only one problem your never on i have tried to find you on it
28-11-2007, 19:15 #6
- Jan 2007
- Location
- LA
- 4,700
Been busy. Got work and college exam coming up.
Host file is for if you want to test things, such as in the case of developers. To use the dns name that you configure for the the host file will have to be done for each machine's host file.
Dyndns.com will allow anyone in the world that uses that name to be able to connect to the server, without first configuring the host file.
