Results 1 to 2 of 2
Thread: TS Problem
    Dec 2007
    Texas
    Unhappy TS Problem
    I recently downloaded the latest version of TS but its not working properly.
    It installs just like normal and sets up like normal but when I bind a key for push to talk it doesnt activate nor does voice activation. I have uninstalled and re-installed several times and its still the same. I even went in HKEY_LOCAL_MACHINE to remove all traces but there is no file in there. The reason I searched in this folder is after re-installing TS it is keeping all server info ie. IP, server name and log in info. The sound card is an onboard 5.1 on an ASUS M2N-E SLi motherboard.
    BHKai is offline -= Undercover TeamSpeak Fanatic =-
    Jan 2007
    LA
    4,700
    The that holds the config is in the appdata folder in the Teamspeak directory.
    Make sure to check that you have the correct input and output devices selected with you are using TS. Plus the recording level is at the correct level so that other people can hear you.
  1. echo problem
    By wilber in forum [TeamSpeak 2] Client Support
    Last Post: 06-10-2007, 02:09
  2. CS Problem!
    By crem in forum [TeamSpeak 2] Client Support
    Last Post: 01-09-2002, 13:22
