Results 1 to 2 of 2
Thread: Output Volume Extremly Soft
29-01-2008, 20:47 #1
-= TeamSpeak User =-
- Jan 2008
- Location
- Maryland
- 1
I have had an issue with one particular TS server for the last several months and I have not been able to figure out what the problem is. I can connect to the server just fine and hear others in it ok as well. However multiple other regular users of that server report that I always sound extremely low volumed.
I have gone into my settings and turned up my out-put volume as high as it will go. And still is not fixing this problem. Im thinking it can't be my mic, because I have gone to other TS servers as well as Ventrillo servers where I am told I sound just fine.
What I can't figure out is wheather its a case of just needing to perhaps re install TS or if that particular server is simply not compatible with my sound system, (though I don't understand how that could be the case) Or if there is just a problem with that server. Thanks in advance for any suggestions.
03-02-2008, 21:42 #2
Maybe something really weird like teamspeak might be setup to use your mic built in a web cam or something i know a mate who kept getting it... drove him mad ... but ye go under settings > options and check which input device its using
output volume
By fiKskE in forum [TeamSpeak 2] Client SupportReplies: 2Last Post: 09-07-2005, 17:19 -
Output and Input Volume?
By TylenolMan in forum [TeamSpeak 2] General QuestionsReplies: 14Last Post: 08-05-2005, 00:32 -
Help... output volume very low!
By Bernman2 in forum [TeamSpeak 2] Client SupportReplies: 0Last Post: 02-09-2004, 05:24
