Results 1 to 5 of 5
Thread: Teamspeak sound output crackling
12-02-2008, 23:18 #1
-= TeamSpeak User =-
- Feb 2008
- Location
- england
- 1
I'm running Teamspeak using the aoss command, my mic doesn't work if i dont use aoss. (ubuntu gutsy)
Other people on teamspeak crackly, as is the voice saying "connection established" etc. My music isn't crackly, nothing else that i know of it, only teamspeak. It makes it very hard to understand people talking - when i talk to them they inform me everything is fine. I'm not fussed if i only have to have teamspeak running and no other audio, i just want teamspeak working right.
Does anybody have a fix?
07-05-2008, 12:21 #2
- May 2008
- Location
- England
- 1
I've got a similar problems with the crackling. I found that it seems to help a bit if I switch the quality up and down a few times, but this isn't a definitive fix and doesn't really make much sense. I wish the Linux version was as polished as the windows one.
08-05-2008, 04:30 #3
- Apr 2008
- Location
- Missouri, USA
- 7
You can try adding this to your .asoundrc file:
Reboot your computer and it should work. At least it did for me on Ubuntu 7.10.Code:pcm.card0 { type hw card 0 mmap_emulation true } pcm.!playback { type dmix # dmix plugin for mixing the output ipc_key 1234 # an uniqe number slave { pcm "card0" period_time 0 period_size 1024 buffer_size 8192 rate 44100 } bindings { 0 0 1 1 } } pcm.!capture { type dsnoop # dsnoop plugin for input ipc_key 5678 # another uniqe number slave { pcm "card0" period_time 0 period_size 1024 rate 44100 } } # # combined playback/capture device # pcm.!duplex { type asym playback.pcm "playback" capture.pcm "capture" } # # making the playback/capture device default # pcm.!default { type plug slave.pcm "duplex" } # # for oss compatibility (maybe) # pcm.!dsp { type plug slave.pcm "duplex" } ctl.!mixer0 { type hw card 0 }
And I got the above code form here
Oh, And if you don't have an .asoundrc file in your home directory then you'll have to add one.
just use gedit are what ever text editor you use.
Hope that helps.
09-05-2008, 11:21 #4
- May 2008
- 4
Yep, same problem under Slackware 12.0.
TeamSpeak doesn't use ALSA drivers, this is the real problem.
21-07-2008, 21:55 #5
- Jul 2008
- Location
- italy
- 1
Team Speak does not seem to be built for any modern linux distribution, it looks more like an oldish windows gaming enthusiast application, using oss and pascal is a terrible choice for us, actually its performances are poor compared to other newer systems, Mumble in primis. The problem is convincing communities to switch to better programs, if teamspeak 3.0 won't be fast out i believe and HOPE that, with this new spreading of linux, mumble will soon increase popularity.
I have the same problem with gentoo x86_64 and Analog Devices AD1986A, looks like there is no way to solve it, apart from substantially removing microphone support. This sucks SO much.Last edited by Kibuzo; 21-07-2008 at 22:11.
TeamSpeak picks up system output sound
By Cunjo in forum [TeamSpeak 2] Client SupportReplies: 11Last Post: 15-05-2007, 15:39 -
All sound output from my comp going through mic...
By Twenty in forum [TeamSpeak 2] Client SupportReplies: 4Last Post: 30-09-2006, 17:25 -
Teamspeak needs to release higher codecs, at least 44k
By Gnomore in forum [TeamSpeak 2] General QuestionsReplies: 21Last Post: 08-08-2005, 21:17 -
no Sound in Descent3 when TeamSpeak running
By maarten in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 08-06-2003, 11:21
