Results 1 to 4 of 4
    Feb 2008
    canada
    2 users droping at the same time while others have no problem
    heres the problem, 2 out of the 5 main users of my ts will dissconnect randomly but both of them will always dissconnect at the same time. they can connect right away again.
    4 of us are on the same isp, 1 of the 2 that disconnect are on the same isp, while the other 1 that discconects is on dsl 2000 miles away.
    I used to work in our isp and still have some pull there, and I got them to check all of our connections( the server and the one that dissconnects) and theres no problems, they did a total reprogram of the lines just to be safe.
    The TS server is hosted on a Winxp sp2 machine, with no firewall/no router atm. does go through a switch but I cant see that being a problem.
    I turned on all the logging I could and all it says is the client has dissconnected.
    Im totaly out of ideas why this is happening, its always to the same 2 poeple and always at the same time. Any help would be useful.
    Feb 2008
    United Kingdom
    Thats definately an unheard of issue. I'm sitting here scratching my head.
    Jan 2003
    The Netherlands
    1,425
    if it says disconnect it looks to me like somethign is going wrong with packages.. And TS client thinks he's disconnected.
    Are you sure your upload speed is enough to play a game and host TS at the same time?
    Feb 2008
    canada
    yes im sure I've got enough Bandwidth I've had upwords of 30 poeple on my ts with no problems. and if bandwidth was teh case I really dont think it would only be the same two poeple and at the same time.
    I also changed my nics in my computer thinking along the same package droping line and still does it. but that was a long shot since it always goes back to being the same 2 users that have nohting in common that might cause this problem, they have differnt isp, routers, nics, one is useing vista, other is xp
    heres a post from my server log so you can see, I edited the ips and nick names, the times are random I at least cant see a pattern to them
    15-02-08 03:16:45,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:16:45,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:16:53,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:16:54,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:16:55,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:16:56,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:17:06,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:17:07,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:17:08,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:17:09,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:17:19,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:17:21,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:17:21,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:17:23,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:17:33,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:17:35,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:17:35,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:17:37,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:17:46,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:17:48,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:17:49,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:17:51,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:17:59,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:18:01,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:18:03,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:18:05,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:18:12,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:18:14,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:18:17,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:18:19,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:18:25,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:18:28,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:18:30,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:18:32,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:18:39,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:18:41,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:18:44,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:18:46,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:18:52,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:18:54,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:18:58,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:19:00,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:19:05,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:19:07,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:19:12,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:19:14,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:19:18,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
    15-02-08 03:19:20,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Blue]
    15-02-08 03:19:26,ALL,Info,AccessLog, SID: 1 client connected [IP: 222.222.222.222, Nick: Mr. Black, Version: 2.0.32.60]
    15-02-08 03:19:28,ALL,Info,AccessLog, SID: 1 client disconnected. [Nick: Mr. Black]
    15-02-08 03:19:32,ALL,Info,AccessLog, SID: 1 client connected [IP: 111.111.111.111, Nick: Mr. Blue, Version: 2.0.32.60]
  1. MySQL startup error: SQL files not found
    By winetown in forum [TeamSpeak 2] Server Support
    Last Post: 05-06-2008, 07:43
  2. Users cant TALK!!! major problem...
    By PIMPSTA in forum [TeamSpeak 2] Server Support
    Last Post: 01-09-2004, 22:49
