Results 1 to 6 of 6
    Feb 2008
    USA
    libgcc_s.so.1 must be installed for pthread_cancel to work
    This is what I get when I try to run the latest server:
    $ ./server_linux
    Aborted
    I am running on an AMD64 Fedora Core 6 box. Thanks.
    Feb 2008
    USA
    I got this to work. Apparently I had the 64-bit version of that library, while the TS server wants the 32-bit one. I obtained the last 32-bit rpm for libgcc for Fedora 6 from rpm.pbone.net, then did:
    rpm -ivh libgcc-4.1.2-13.fc6.i386.rpm
    It installed the 32-bit version side-by-side next to my 64-bit version.
    And now it is running. Hope this helps someone.
    Mar 2008
    spain
    you did it!. thank you very much Gremmie!.
    that was i did in a debian amd64 server (you need ia32-libs package installed previously, more info here):
    quick way (admin rights needed):
    sudo apt-get install ia32-libs
    1.- download the libgcc package for i386
    http://packages.debian.org/etch/libgcc1
    2.- extract the package in a temp directory, in my case:
    dpkg -x libgcc1_4.1.1-21_i386.deb ./libgcctemp
    3.- copy libgcc_s.so.1 in /lib32 (linked to /emul/ia32-linux/lib):
    sudo cp ./libgcctemp/lib/libgcc_s.so.1 /lib32
    4.- if *the force* is with you, you are done! i hope so...
    Nov 2009
    UK
    Thanks to both of you! I had the same problem while installing Bitami LAMP stack on Debian Lenny. topete's comment helped me get it to work on my ADM64 system, except that I got the package from http://packages.debian.org/lenny/libgcc1 instead of http://packages.debian.org/etch/libgcc1
    Jan 2012
    teamspeak2 erro
    /teamspeak/tss2_rc2$ ./teamspeak2-server_startscript st art
    starting the teamspeak2 server
    ./teamspeak2-server_startscript: line 7: 28735 Abandon ./server_ linux -PID=tsserver2.pid
    My server is debian already have installed Webmin
    thread has been merged
    Mar 2012
    This also helps with IronKey secure USB drive...
    The software handling access to USB drive internals, when launched with ./ironkey, failed with a complaint of lack of aforementioned libs (not found). apt-get install only was enough to deal with that, after that IronKey secure USB drive works on amd64 Debian Squeeze linux and now I can use that expensive piece of USB stick nicely under Linux, thanks to you.
    Thx for tip!
  1. Have to have TS on top for it to work?
    By Bargy in forum [TeamSpeak 2] Client Support
    Last Post: 19-04-2011, 00:20
  2. My mic start work but fail after a time!
    By RodolfoJV in forum [TeamSpeak Classic] General Questions
    Last Post: 18-01-2006, 20:48
  3. Links won't work in Opera
    By Siberian in forum [TeamSpeak 2] Client Support
    Last Post: 05-01-2006, 00:36
  4. Everything installed but ICONS Buttons wont work
    By Unhappyatnyc in forum [TeamSpeak 2] Server Support
    Last Post: 10-04-2005, 22:03
  5. Cant get TeamSpeak 2 to work under KDE
    By Goniak in forum [TeamSpeak 2] Client Support
    Last Post: 02-04-2003, 21:05
