Page 1 of 16 12311 ... LastLast
Results 1 to 15 of 236
    Jun 2002
    California, USA
    18
    FreeBSD guide to TeamSpeak2_RC2
    For the BSD 4.5+ users of RC2 [201916]:
    1. Download your Linux server version of RC2
    2. Upload it to the directory where you want tss2 setup.
    3. Run:
    a) bunzip2 ts2_server_rc2_201916.tar.tar
    b) tar -xf ts2_server_rc2_201916.tar.tar.out
    c) cd tss2_rc2
    4. Go to: ftp://voice.teamspeak.org/developer/server/
    a) Save b22_server_linux for linux to your computer.
    b) Upload b22_server_linux to your server's tss2_rc2 directory
    5. Run: (in the tss2 directory)
    a) rename b22_server_linux server_linux
    b) brandelf -t Linux server_linux
    c) chmod 777 server_linux
    6. Be sure you have installed
    a) linux_base1.7_2
    b) sql support installed on your server (package?)
    7. Run:
    a) sh tss.minimal_startscript start
    [ If you still have unaddressed errors try to find the answer on these forums. ]
    8. In your tss2_rc2 directory a file titled "server.log" will be created by step 7. Open this file and find the superadmin and admin passwords. WRITE THEM DOWN!
    9. If you got a PID (process ID) from step 7 and no errors then you may open your web browser and in the address line type your new Teamspeak2_RC2 server IP address and the port number: 14534
    "xxx.xxx.xxx.xxx:14534"
    10. login and play as you please. I hope this helps, take care!
    Dec 2002
    Vancouver, Canada
    35
    how can I find out if I have Linux Base and sql support installed?
    and where can I find them if I need them?
    Jun 2002
    california
    19
    use the pkg_info command to see what it is installed.. look for the linux base.. as for installinga different base, you can use the ports system accessed via /stand/sysinstall
    For me I could only get 7.1.1 via this method, I need to dig a little to see how to grab ports that are not listed for a given installation(4.7 stable in this case).
    So far these steps have not worked with 7.1.1 base, although it launches, there are many many sql errors as it tries to wright out the data...
    Dec 2002
    Vancouver, Canada
    35
    I have Linux_base 7.1_1
    how do I get 7.1_2?
    Jun 2002
    california
    19
    Machine: Can you expand on this part a bit, I'm not sure I follow you:
    Jun 2002
    California, USA
    18
    Unhappy
    okie dokie:
    The FreeBSD server that I am on has webmin running. It makes it possible for me to view my stuff in n00b mode. As I am a Unix n00b.
    I have the MySQL Module running. Beyond that I am uncertain. Perhaps the TS Devs would be kind enough to comment here on where to look for guidance on this.
    As far as linux_base1.7_2, just goto google as I did and look for a hit that lets you download it. I used webmin to install it once I uploaded it.
    Perhaps again the Devs could comment on package finding and installation. As I am semi-ignorant of it.
    sorry guys dont string me up please.
    Dec 2002
    Vancouver, Canada
    35
    I suppose I would be classed as a unix noobie too...
    web admin? for unix??? what?
    are you or are you not running this unix server from your own house?
    mine is sitting about 2 inches to the right of the horrible winblows machine I am typing on.
    Mar 2003
    London UK
    66
    No joy here just loads of:
    OpenSQL Error: database is locked in query:...
    ExcecSQL Error: database is locked in query: ....
    Errors
    Still runs just doesnt work
    Dec 2002
    Vancouver, Canada
    35
    that's a little ozymoronic isn't it?
    still runs just doesn't work?
    anyways... I'll be around... my system crashed during an upgrade... (human error all the way)
    so I'm installing FreeBSD 5.0
    should be done in a day or two.
    Mar 2003
    London UK
    66
    hehe not being able to add users / channels does make it kinda useless :P
    Mar 2003
    USA
    51
    There seems to be a gross lack of information as to how we're supposed to setup MySQL to work with teamspeak.
    I just let "login failed" when I try to login to the web console with the admin accounts listed in the server.log file, amonst the string of SQL errors.
    Dec 2002
    Vancouver, Canada
    35
    ok... FreeBSD 5.0 works with it... web admin and all...
    I did a fresh install of BSD from 4.7 to 5.0
    it works great.
    the only problem I'm having is the infinite load time for the web admin.
    it's odd...
    however... everything else works!
    the database, the sql.. everything...
    have fun ppl.
    Mar 2003
    London UK
    66
    Yep confirmed just tried it our 5.0 box and it does indeed work nice 1 AbbraCadaver.
    Mar 2003
    USA
    51
    I can only assume there's something I need to do manually in MySQL. . . what is it?
    Am I completely missing it, or is there no docs for TeamSpeak? I'd kill for a manual.
    Mar 2003
    London UK
    66
    It doesnt use mysql it uses sqlite.
  1. TeamSpeak server on FreeBSD - Getting it done quick
    By Kordau in forum [TeamSpeak 2] Server Support
    Last Post: 07-08-2008, 22:47
  2. Teamspeak2 für FreeBSD amd64
    By CRAZyBUg in forum [TeamSpeak 2] General Questions
    Last Post: 12-09-2007, 20:10
  3. FreeBSD 6.0, latest TS2 -- cannot play AND use TS.
    By bsduser in forum [TeamSpeak 2] Client Support
    Last Post: 29-03-2006, 17:00
  4. FreeBSD Support
    By Degas in forum [TeamSpeak 2] General Questions
    Last Post: 31-10-2004, 05:15
  5. FreeBSD 5.1 microphone/speakers muted
    By curt in forum [TeamSpeak 2] Client Support
    Last Post: 16-06-2003, 01:25
