Results 1 to 2 of 2
    Feb 2008
    Cincinnati
    Required Memory? Error Starting...
    How much memory is required to run TeamSpeak? I know the system requirements for the server running on linux is 34-64MB RAM, so then why isn't it working for me?
    Currently I am trying to run TeamSpeak on CentOS Linux 5, with 128MB total memory. The error log leads me to believe that I don't have enough memory. How much do I need? Could I use a different distribution of Linux with this amount of memory and it would work? Or what is the problem?
    Below is the log
    16-04-08 14:08:07,ALL,Info,server, Server init initialized
    16-04-08 14:08:07,ALL,Info,server, Server version: 2.0.23.19 Linux
    16-04-08 14:08:07,ALL,Info,server, Starting VirtualServer id:1 with port:8767
    16-04-08 14:08:07,ALL,Info,server, Started VirtualServer id:1 with port:8767
    16-04-08 14:08:07,ALL,Info,server, Starting VirtualServer id:2 with port:8768
    16-04-08 14:08:07,ALL,Info,server, Started VirtualServer id:2 with port:8768
    16-04-08 14:08:08,ERROR,All,WEBINTERFACE, WebInterface startup failed with port 14534, Exception:Thread creation error: Cannot allocate memory
    16-04-08 14:08:08,ERROR,All,TCPQUERY, TCPQuery startup failed with port 51234, Exception: Thread creation error: Cannot allocate memory
    Feb 2008
    Cincinnati
    Here is another log, I switched the distribution to Redhat Linux Fedora 8. There is still 128MB RAM, I did a clean install, there is nothing else running on the server I simply followed the instructions for installing found in the FAQ sticky with the install guide, literally copying and pasting commands, with the exception of passwords and I used the later version rather than the older one the thread uses.
    Here is the log:
    -------------- log started at 16-04-08 15:23 -------------
    16-04-08 15:23:15,ALL,Info,server, Server init initialized
    16-04-08 15:23:15,ALL,Info,server, Server version: 2.0.23.19 Linux
    16-04-08 15:23:15,WARNING,Info,SQL, created table ts2_servers
    16-04-08 15:23:15,WARNING,Info,SQL, created table ts2_server_privileges
    16-04-08 15:23:16,WARNING,Info,SQL, created table ts2_channels
    16-04-08 15:23:16,WARNING,Info,SQL, created table ts2_channel_privileges
    16-04-08 15:23:16,WARNING,Info,SQL, created table ts2_clients
    16-04-08 15:23:16,WARNING,Info,SQL, created table ts2_bans
    16-04-08 15:23:16,ALL,Info,server, Starting VirtualServer id:1 with port:8767
    16-04-08 15:23:16,ALL,Info,server, Started VirtualServer id:1 with port:8767
    16-04-08 15:23:16,WARNING,Info,SERVER, Default VirtualServer created
    16-04-08 15:23:16,WARNING,Info,SERVER, admin account info: username: admin password: XXXXX
    16-04-08 15:23:16,WARNING,Info,SERVER, superadmin account info: username: superadmin password: XXXXX
    16-04-08 15:23:16,ERROR,Info,server, EThread: Thread creation error: Cannot allocate memory
    --------------- log ended at 16-04-08 15:23 --------------
  1. Thread creation error: Cannot allocate memory
    By MiniMe in forum [TeamSpeak 2] Server Support
    Last Post: 30-03-2008, 14:54
  2. Games Crash when Running TS
    By guest_post in forum [TeamSpeak 2] Client Support
    Last Post: 27-12-2005, 01:09
  3. żż Memory Leaks ??
    By nicedreams242 in forum [TeamSpeak 2] Server Support
    Last Post: 10-04-2005, 13:33
  4. [Fedora Core 2] TeamSpeak starts numerous processes and hogs memory
    By Proton in forum [TeamSpeak 2] Server Support
    Last Post: 29-11-2004, 18:42
