Results 1 to 10 of 10
Thread: Need Some PHP Help
25-04-2008, 17:57 #1
-= TeamSpeak Addict =-
- Jun 2006
- Location
- Ireland
- 269
Need Some PHP Help
OK I need some php help here.
I know this hasnt realy got much to do with Teamspeak, but I dont know who else to get help from but you brainy people here.
Ok I need to extract data from an XML file. I can get it into arrays but dont know how to extract it out of the array.
Here the PHP
PHP Code:<?php
$xml = simplexml_load_file("file.xml");
$result = $xml->xpath("weather");
print_r($result);
The above prints out the following.
The part that I need the most is [data] => Cloudy.Code:Array ( [0] => SimpleXMLElement Object ( [@attributes] => Array ( [module_id] => 0 [tab_id] => 0 ) [current_conditions] => SimpleXMLElement Object ( [condition] => SimpleXMLElement Object ( [@attributes] => Array ( [data] => Cloudy ) ) [temp_f] => SimpleXMLElement Object ( [@attributes] => Array ( [data] => 55 ) ) [temp_c] => SimpleXMLElement Object ( [@attributes] => Array ( [data] => 13 ) ) [humidity] => SimpleXMLElement Object ( [@attributes] => Array ( [data] => Humidity: 82% ) ) [icon] => SimpleXMLElement Object ( [@attributes] => Array ( [data] => /images/weather/cloudy.gif ) ) [wind_condition] => SimpleXMLElement Object ( [@attributes] => Array ( [data] => Wind: S at 16 mph ) ) ) ) )
If anyone can help I would be very greatful.
Thanks,
Andy
25-04-2008, 18:46 #2
-= TeamSpeak Fanatic =-
- Jul 2006
- 1,573
do the official php sites not provide any xml reader examples?
25-04-2008, 18:47 #3
- Jun 2006
- Location
- Ireland
- 269
Yes that is were I got the bit of php code in my previous post, but I just want to know how to get the data out of the arrays.
30-04-2008, 20:50 #4
- Jun 2006
- Location
- Ireland
- 269
Anyone got any solutions???
06-05-2008, 17:32 #5
-= TeamSpeak User =-
- May 2008
- Location
- Berlin, Germany
- 18
if you could post the xml file i could tell you how to get the data.
09-05-2008, 14:04 #6
- Jun 2006
- Location
- Ireland
- 269
Sorry for not replying quicker been bussy with other issues.
The XML is as follows:
Thanks for trying to help me, much apretiated.Code:<xml_api_reply version="1"> − <weather module_id="0" tab_id="0"> − <forecast_information> <city data=""/> <postal_code data=""/> <latitude_e6 data="54650001"/> <longitude_e6 data="-6219999"/> <forecast_date data="2008-05-09"/> <current_date_time data="2008-05-09 07:50:00 +0000"/> <unit_system data="US"/> </forecast_information> − <current_conditions> <condition data="Mostly Cloudy"/> <temp_f data="59"/> <temp_c data="15"/> <humidity data="Humidity: 77%"/> <icon data="/images/weather/mostly_cloudy.gif"/> <wind_condition data="Wind: SE at 8 mph"/> </current_conditions> − <forecast_conditions> <day_of_week data="Today"/> <low data="48"/> <high data="64"/> <icon data="/images/weather/mostly_cloudy.gif"/> <condition data="Mostly Cloudy"/> </forecast_conditions> − <forecast_conditions> <day_of_week data="Sat"/> <low data="46"/> <high data="62"/> <icon data="/images/weather/chance_of_rain.gif"/> <condition data="Chance of Rain"/> </forecast_conditions> − <forecast_conditions> <day_of_week data="Sun"/> <low data="50"/> <high data="68"/> <icon data="/images/weather/mostly_sunny.gif"/> <condition data="Partly Sunny"/> </forecast_conditions> − <forecast_conditions> <day_of_week data="Mon"/> <low data="50"/> <high data="69"/> <icon data="/images/weather/mostly_sunny.gif"/> <condition data="Mostly Sunny"/> </forecast_conditions> </weather> </xml_api_reply>
Andy
14-05-2008, 23:28 #7
- May 2008
- Location
- Berlin, Germany
- 18
ok i developed a class to parse this thingie.
Actually a class is not needed but i thought it might be nice for extending it.
At the moment the class just parses the xml (which is loaded via URI) and returns all it contents as an associative array via "getall()"-method.
I tried to implement a "getone($which_one)"-method but didnt worked yet because the array is multidimensional. I ve just to work on on that xD
So there is the code for you (the information is currently loaded from "weather.xml" in the current working directory. If you want to change this, just pass on a filename to the constructor to load from
Best regards FrankPHP Code:<?php
error_reporting(E_ALL);
class weatherxml {
public $version;
public $module_id;
public $tab_id;
public $city;
public $postal_code;
public $latitude_e6;
public $longitude_e6;
public $forecast_date;
public $forecast_date_timestamp;
public $current_date_time;
public $current_date_time_timestamp;
public $unit_system;
public $current;
public $forecast;
public function __construct($url = "weather.xml") {
if(($xml = simplexml_load_file($url)) === false)
die("XML Reading Error");
$this->version = (int) $xml->attributes()->version;
$this->module_id = (int) $xml->weather->attributes()->module_id;
$this->tab_id = (int) $xml->weather->attributes()->tab_id;
$shortcut = &$xml->weather->forecast_information;
$this->city = (string) $shortcut->city->attributes()->data;
$this->postal_code = (int) $shortcut->postal_code->attributes()->data;
$this->latitude_e6 = (int) $shortcut->latitude_e6->attributes()->data;
$this->longitude_e6 = (int) $shortcut->longitude_e6->attributes()->data;
$this->forecast_date = (string) $shortcut->forecast_date->attributes()->data;
$this->forecast_date_timestamp = strtotime($this->forecast_date);
$this->current_date_time = (string) $shortcut->current_date_time->attributes()->data;
$this->current_date_time_timestamp = (strtotime(substr($this->current_date_time, 0, 19)));
$this->unit_system = (string) $shortcut->unit_system->attributes()->data;
$shortcut = &$xml->weather->current_conditions;
$this->current = array();
$current = &$this->current;
$current["condition"] = (string) $shortcut->condition->attributes()->data;
$current["temp_f"] = (int) $shortcut->temp_f->attributes()->data;
$current["temp_c"] = (int) $shortcut->temp_c->attributes()->data;
$current["humidity"] = (int) $shortcut->humidity->attributes()->data;
$current["icon"] = (string) $shortcut->icon->attributes()->data;
$current["wind_condition"] = (string) substr($shortcut->wind_condition->attributes()->data, 6);
$forecast = &$this->forecast;
//We have 3 forecasts
$i = 0;
foreach($xml->weather->forecast_conditions as $input) {
//the key will be the timestamp for the day
//for which the forecast is
$c_fc = &$forecast[$i];
$c_fc["day_of_week"] = (string) $input->day_of_week->attributes()->data;
$c_fc["low"] = (int) $input->low->attributes()->data;
$c_fc["high"] = (int) $input->high->attributes()->data;
$c_fc["icon"] = (string) $input->icon->attributes()->data;
$c_fc["condition"] = (string) $input->condition->attributes()->data;
$i++;
function getall() {
return (array) $this;
$weather_parser = new weatherxml();
$weather_info = $weather_parser->getall();
<pre>
<?php
print_r($weather_info);
</pre>Last edited by Ch3ck3r; 17-05-2008 at 01:15.
16-05-2008, 11:04 #8
- Jun 2006
- Location
- Ireland
- 269
Lovely I cant thank you enough for helping me out, Thanks sooo much.
I havent tried it yet as I am currently in uni, but ill be home tomo so ill run it then.
So all ill need to do is work out how to pull the exact piece of data i need from the array.
Emmm any ideas anyone on how to pull data from a multidimensional array?
Thanks soo much Ch3ck3r, Ill get back to you on how it works.
Andy
17-05-2008, 01:14 #9
- May 2008
- Location
- Berlin, Germany
- 18
getting the data you want is really easy.
The first thing you need to do is to get the data which is really easy:
now $data contains the following data:PHP Code://Location of the xml file with the information
$url = "weather.xml";
//Parse the file
$parsed = new weatherxml($url);
//Get the data
$data = $parsed->getall();
so now, if you need (e.g.) the condition of the forecast in 3 days this would be the wayCode:Array ( [version] => 1 [module_id] => 0 [tab_id] => 0 [city] => New York [postal_code] => 0 [latitude_e6] => 54650001 [longitude_e6] => -6219999 [forecast_date] => 2008-05-09 [forecast_date_timestamp] => 1210284000 [current_date_time] => 2008-05-09 07:50:00 +0000 [current_date_time_timestamp] => 1210312200 [unit_system] => US [current] => Array ( [condition] => Mostly Cloudy [temp_f] => 59 [temp_c] => 15 [humidity] => 0 [icon] => /images/weather/mostly_cloudy.gif [wind_condition] => SE at 8 mph ) [forecast] => Array ( [0] => Array ( [day_of_week] => Today [low] => 48 [high] => 64 [icon] => /images/weather/mostly_cloudy.gif [condition] => Mostly Cloudy ) [1] => Array ( [day_of_week] => Sat [low] => 46 [high] => 62 [icon] => /images/weather/chance_of_rain.gif [condition] => Chance of Rain ) [2] => Array ( [day_of_week] => Sun [low] => 50 [high] => 68 [icon] => /images/weather/mostly_sunny.gif [condition] => Partly Sunny ) [3] => Array ( [day_of_week] => Mon [low] => 50 [high] => 69 [icon] => /images/weather/mostly_sunny.gif [condition] => Mostly Sunny ) ) )
This would output "Mostly Sunny". I've made the corresponding line bold in the data above, so that you can find what is printed out.PHP Code:echo $data["forecast"][3]["condition"]
I hope you are able to use this now ^^
17-05-2008, 12:37 #10
- Jun 2006
- Location
- Ireland
- 269
Ch3ck3r your a genius, it works a charm. Thank you, Thank you.
I cant thank you enough for helpen me.
Andy
.ASP TeamSpeak Script (No PHP please)
By oceans777 in forum [TeamSpeak 2] Addons & ScriptsReplies: 3Last Post: 12-11-2007, 03:52 -
FreeBSD and MySQL
By Paterson in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 18-01-2006, 08:35 -
show stats on PHP
By Ace-SG1- in forum [TeamSpeak 2] Addons & ScriptsReplies: 3Last Post: 18-12-2005, 17:51 -
TS PHP Script
By Neonis in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 05-10-2005, 10:05 -
TS2 Account management from php
By Bones_taw in forum [TeamSpeak 2] Addons & ScriptsReplies: 1Last Post: 12-03-2005, 20:35
