Results 1 to 6 of 6
29-07-2002, 15:02 #1Skelch Guest
Sound blaster Audigy wont work :(
I had a cheapo ensoniq sound card, and TS worked Great. Now I just installed Sound Blaster Audigy Platinum and I can still hear everyone else, but I can not talk. When I do use my mike I can hear my own voice through my speakers, but it is not broadcasting
Computer stats
1.5 gig P4
640 megs ram
Geforce 4 Ti 4400
lots of free hd space
win xp
soundblaster audigy plat
Thanks in advance
Roy aka Skelch
29-07-2002, 15:17 #2
-= TeamSpeak Addict =-
- Jun 2002
- Location
- Houston, Tx
- 170
disable all the extra creative bs features and you will be fine. check for hear what i say or something along those lines also check your windows mixer settings under recording and check mic settings. while i hate that card its not the card at fault its the default settings you need to change
02-08-2002, 00:20 #3
-= TeamSpeak User =-
- Jun 2002
- 8
This is gonna sound strange so let me explain. I have a sound blaster Live but it may work for you too.
TS was working great for me on a new host and then suddenly I couldn't be heard by anyone. I tried the loopback and nothing. I tried sound recorder and nothing. I could hear my voice in the speakers. I restored my system and it worked again. So I started testing.
I ran a program called WinProducer which I ran when the poroblem occured. I heard the voifce sound change slightly and then all sound recording programs didn't work again. I thought that was funny as I had used it before and no problems. So then I ran Roger Wilco, made a server and then turned it off and it fixed the problem which was the program I used before I switched to Team Speak which is why I hadn't noticed the problem before.
It must set some settings somewhere. Its worth a shot unless someone knows why that works.
PS: I deleted the WinProducer program but your problem sounds the same.
06-08-2002, 11:51 #4
-= TeamSpeak Lover =-
- Aug 2002
- Location
- UK
- 40
Ive got SB audigy and i think the problem ur having is that the creative surround sound mixer (or equivalent software) is set by default to record/transmit through line-in or other device. Open the mixer and make sure that the sound recording device is set to mic and also that it isnt muted.
If like me u have lots of different audio programs, any one of them can cause a similar problem.
I have found that when certain audio programs are run the mixer will default back to line-in or mute the mic, so i allways check it if my TS goes up the swanney :P
Also if ur mic volume is low run the adio setup wizzard, it can also help (but i bet u knew that
06-08-2002, 14:04 #5
- Jun 2002
- Location
- Netherlands
- 136
ohja, the awefull "What you hear" feature of Creative..
also there is a bug with Microsofts DirectX and Creative's audigy... You might have to set the Sound Hardware acceleration to low... (using dxdiag.exe)
22-08-2002, 03:01 #6GOD_MERCURY Guest
Hey Barking, you hit the nail on the head with the "what you hear" Moved it to the mic key and whala problems solved.
Only thing is team mates said i sounded like i was in the bottom of a tunnel. Reverb and echo's.
Thanks For the help Barking_Mad
Mic problems with sound blaster audigy card
By Robin hood in forum [TeamSpeak 2] General QuestionsReplies: 0Last Post: 09-05-2006, 01:20 -
Combined headset/microphone connection problems with Sound Blaster Live 24 bit card
By harcat in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 11-04-2006, 22:06 -
Sound Blaster Audigy 2 ZS Gamer
By agenttuna in forum [TeamSpeak 2] Client SupportReplies: 1Last Post: 16-01-2006, 08:49 -
Sound Blaster Audigy 2 ECHO
By XblackdemonX in forum [TeamSpeak 2] Client SupportReplies: 2Last Post: 05-12-2005, 21:04 -
sound blaster audigy 2 zs und kx mixer problem : (((
By icabrain in forum [TeamSpeak 2] Client SupportReplies: 3Last Post: 23-12-2004, 12:06
