Results 1 to 10 of 10
    Jan 2009
    Holland
    6
    Hearing a 'tinging' sound when trying to talk
    Hiya,
    Okay so... when I first installed TeamSpeak, and started it, it gave me an error something like TDSoundIn.Open No drivers detected or something like that. I was still able to join servers though, and I could still hear other people talking, but when I tried to talk it gave me a tinging sound (or ringing sound, you know what I mean).
    So I googled for a solution, which told me to go to settings, options and put it from "Wave" to "DirectSound". Doing that, I received the same error (the no drivers detected one), and it automatically switched back to Wave.
    Now I reinstalled my sound drivers and reinstalled TeamSpeak. The error is now gone when I start up teamspeak, and I am also able to switch between Wave and DirectSound. Additionally, directsound now has 2 extra options for devices for me to choose from. But still, I cannot seem to talk on teamspeak. The error is gone, but it just gives me a tinging sound whenever I push the '1' button to talk (the button I set for push to talk).
    I have 2 headsets plugged in, one is a sennheiser which I listen with, one is a logitech which has the microphone I would like to talk through. A few months ago I used the logitech one for both hearing and speaking, and it worked fine, however, that was on another computer, an older one, with windows XP. I now run Windows Vista Ultimate.
    Any solutions?
    It might be my microphone or something, because I did plug in the headset (and yes, pink for microphones, I know that). When I activate the test mode in TeamSpeak for microphones it's not giving any signal either. So maybe it's somewhere in the settings of TeamSpeak, I'm just not sure what to do, I tried alot of stuff.
    Greets, berm
    Nov 2008
    United States
    1,790
    If i understand your "tinging" to be what i think it is, then
    http://forum.teamspeak.com/showthread.php?t=44181
    Based on Windows XP. Not sure about vista
    1. Start > control panel > Sounds and audio devices.
    2. New window popped up, click on the tab "sounds"
    3. At the bottom you'll see a "tree" lay out. At the top should be windows. Under windows go to default beep.
    4. Change it to None (there's a drop down menu)
    5. Click apply.
    http://usera.ImageCave.com/Zero/Teamspeak2.jpg
    There's a picture to help guide your efforts. Did that work?
    Jan 2009
    Holland
    6
    I always thought the tinging sound was something from TeamSpeak itself, but I just found out it's the vista default system beep. Ok, I did these 5 steps, and I disabled the system sound. But when I try to talk in TeamSpeak now (my push to talk button is Z now) nothing happens. I always heard the system sound until I turned it off. Now I don't hear anything and my icon is not lighting up when I push Z.
    Local Test Mode doesn't do anything either.
    The picture below shows that my system does recognise my microphone. Apparently TeamSpeak doesn't.
    http://i44.tinypic.com/161yhxc.jpg
    Nov 2008
    United States
    1,790
    right click on TS, run as admin.
    Jan 2009
    Holland
    6
    That does not work :/ My icon just won't light up. I'm beginning to wonder if TeamSpeak is compatible with Vista Ultimate :/
    BHKai is offline -= Undercover TeamSpeak Fanatic =-
    Jan 2007
    LA
    4,697
    I have vista Ultimate 64-bit on a laptop with UAC on and ts works.
    When you talk does the bars next to the mic in the pic of you second post turn green to indicate the level of volume?
    Jan 2009
    Holland
    6
    Quote Originally Posted by BHKai View Post
    Yes, but faintly. It only fills up half of the bars when I blow in the mic..
    Jan 2007
    LA
    4,697
    Right click on the mic>properties>levels> What are the sliders at?
    Jan 2009
    Holland
    6
    The sliders were at 20 and 0 Db so thank you, I turned the slider from 20 to 100
    Now, as much as I am ashamed to say this, I just have to admit that the only thing that was wrong is me, not having voice rights on the channel.... that's why it came up with the system beep every time. After I got voice rights I was able to talk just fine. However, when I posted this topic it wouldn't work, even with voice rights. So I guess reinstalling things seemed to work.
    Thanks for the quick replies and help everyone Much appreciated.
    Nov 2008
    United States
    1,790
    thanks for the solution!
  1. No sound from TS. I can talk to others.
    By MmCheeto in forum [TeamSpeak 2] Client Support
    Last Post: 20-01-2006, 01:16
  2. Weird sound while trying to talk
    By Ghost-Buster in forum [TeamSpeak 2] Client Support
    Last Post: 11-03-2005, 10:07
  3. "Beep" sound when pressing button to talk!
    By OurLord in forum [TeamSpeak 2] Client Support
    Last Post: 15-04-2004, 20:56
