Results 1 to 8 of 8
Thread: Low frame rates
    Aug 2009
    USA
    Low frame rates
    When I use Teamspeak with flight simulator FS9 my frame rates are reduced by half.What change if any can I make in TeamSpeak.?
    Thanks,
    Bob
    Nov 2008
    United States
    1,791
    what kind of computer do you have? As in, how fast is your processor, video card, sound card and the works. Do you have the latest video drivers for your card? Teamspeak is not video intensive at all.
    Aug 2009
    USA
    Frame Rates
    The computer is a Power spec a local brand ,dual core,processor is 3.0,video card ATI 4870. 4 m of ram ,win xp
    Put in the ln new drivers two days ago.Thank you for your interest.
    Will do some system maintenance to see if it helps.
    Bob
    Nov 2008
    United States
    1,791
    Latest patch for the game?
    Does this only occur with teamspeak? or do other programs running along with it also cause frame drops?
    Open up TS and FS9. Alt-tab out of FS9, open task manager ( ctrl + alt+ del ) and click the process tab. Right click on it and change hte priority level to the next level up ( above normal if i recall correctly ). Try that and see how that works.
    Aug 2009
    USA
    Ts
    It only hapens with TS,and did the change to high prioty level which helped a little.It must be related to FS9 only as when I run X-plane 9 I get rates up to60-70 with TS on.
    Nov 2008
    United States
    1,791
    Latest directX? Maybe switch from wave to direct or vice versa?
    Other people have had this same problem. A little googling might give you a solution. After quick searching, i found nothing.
    May 2006
    Europe/Czech Rep.
    1,299
    FS ,?? I am pretty sure you will find something on this topic also on this forums.
    Aug 2009
    USA
    Ts
    Thank you all for your responses.FS=Flight Simulator.
    Will keep working on it .Did a flight today on Vatsim with heavy traffic,
    Managed it ok.slow at times shut off TS .Big fly in at EGBB Birmingham UK.
    Bob
  1. Others complain my mic is low.
    By theBureau in forum [TeamSpeak 2] Client Support
    Last Post: 30-09-2007, 02:20
  2. Low mic sound..only in TS
    By udovics in forum [TeamSpeak 2] Client Support
    Last Post: 31-05-2005, 14:30
  3. People say I talk to loud on TS but I'm actually talking very low....
    By FredGSanford in forum [TeamSpeak 2] Client Support
    Last Post: 24-08-2003, 13:54
  4. Low Microphone Level (OSS)
    By SkidMark in forum [TeamSpeak 2] Client Support
    Last Post: 24-03-2003, 13:28
  5. Very low sound?
    By x8668k in forum [TeamSpeak 2] Client Support
    Last Post: 06-03-2003, 14:58
