Results 1 to 11 of 11
    Aug 2008
    German
    78
    Teamspeak 3 and connecting with MySQL
    I've been trying the whole time TS3 server with my MyAQL vebinden too. Unfortunately, this does not work, it only appears when you start the following:
    [code]2009-12-21 09:45:13.131005|INFO |ServerLibPriv | | Server Version: 3.0.0-beta2 [Build: 9398]
    2009-12-21 09:45:13.134311|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2009-12-21 09:45:13.134519|INFO |DatabaseQuery | | dbPlugin version: 1
    2009-12-21 09:45:13.151091|ERROR |DatabaseQuery | | mysql_real_connect() failed with error: Access denied for user 'root'@'localhost' (using password: NO)
    2009-12-21 09:45:13.151226|CRITICAL|ServerLibPriv | | Server() DatabaseError[/ code]
    But when I connect via console () with the following command:
    [code]mysql --host=localhost --port=3306 --user=teamspeak --password=x5gUjs ts3db[/ code]
    Will I be connected to MySQL. Can one help me, where is the problem?
    Sorry for my English, but I can not do it so well and let everything translate with google.
    Greeting
    RavLau
    Dec 2009
    Quote Originally Posted by RavLau View Post
    This message tells you that the Server trys to connect with the user root und no password.
    Dec 2007
    Austria,Linz
    220
    You should delet your mysql password for the user teamspeak....
    try with a file!
    (i) MySQL plugin
    To make your TeamSpeak 3 Server use a MySQL database you need to make sure that the
    "ts3db_mysql" library is located in your servers installation directory. Per default,
    the plugin is using the following parameters:
    * host (127.0.0.1)
    The hostname or IP addresss of your MySQL server.
    * port (3306)
    The TCP port of your MySQL server.
    * username (root)
    The username used to authenticate with your MySQL server.
    * password (<empty>)
    The password used to authenticate with your MySQL server.
    * database (test)
    The name of a database on your MySQL server. Note that this database must be created
    before the TeamSpeak 3 Server is started.
    * socket (<empty>)
    The name of the Unix socket file to use, for connections made via a named pipe to a
    local server.
    All parameters can be customized by creating a INI-style configuration file called
    "ts3db_mysql.ini". For example:
    [config]
    host=localhost
    port=3306
    username=teamspeak
    password=x5gUjs
    database=ts3db
    socket=
    The path and filename of the configuration file can be set using the "dbpluginparameter"
    commandline parameter.
    To start the TeamSpeak 3 Server with MySQL support, you need to specify the "dbplugin"
    commandline parameter. You may also need to specify the "dbsqlcreatepath" parameter if
    you're starting the server instance for the first time since the syntax of the MySQL
    installation files differs from SQLite3.
    Example:
    $ ./ts3server_linux_amd64 dbplugin=ts3db_mysql dbsqlcreatepath=create_mysql/
    Dec 2009
    20
    I have the same Problem i setup this file but it ignores it and try to connect as root.
    My ts3db_mysql.ini contains this and is stored in the maindir from the teamspeakserver.
    [config]
    host=localhost
    port=3306
    username=teamspeak3
    password=mypassword
    database=teamspeak3
    socket=
    output from console
     ./ts3server_linux_amd64 inifile=ts3db_mysql.ini dbplugin=ts3db_mysql dbsqlcreatepath=create_mysql/
    Logging started
    2009-12-22 09:41:30.945098|INFO    |ServerLibPriv |   | Server Version: 3.0.0-beta3 [Build: 9419]
    2009-12-22 09:41:30.948474|INFO    |DatabaseQuery |   | dbPlugin name:    MySQL plugin, (c)TeamSpeak Systems GmbH
    2009-12-22 09:41:30.948557|INFO    |DatabaseQuery |   | dbPlugin version: 1
    2009-12-22 09:41:30.953494|ERROR   |DatabaseQuery |   | mysql_real_connect() failed with error: Access denied for user 'root'@'localhost' (using password: NO)
    Speicherzugriffsfehler
    Whats the Problem ? Why dont use my configfile?
    Greetings
    BlackScript
    Aug 2008
    German
    78
    Quote Originally Posted by GrexAut View Post
    try with a file!
    I have addressed myself to the example where the bottom was ...
    [config]
    host=localhost
    port=3306
    username=teamspeak
    password=x5gUjs
    database=ts3db
    socket=
    So I will use the database without a password?
    Dec 2009
    I've the same problem!
    It keeps ignoring the Username & Password for the mysql connection.
    No matter if I use the config file or the commandline params.
    Jun 2009
    Wuppertal
    48
    [config]
    host=localhost
    port=3306
    username=teamspeak
    password=x5gUjs
    database=ts3db
    socket=
    that is a buggy file
    [config]
    host=localhost
    username=teamspeak
    password=x5gUjs
    database=ts3db
    blankline
    that the correkt
    Dec 2009
    20
    Quote Originally Posted by Prismatech View Post
    [config]
    host=localhost
    port=3306
    username=teamspeak
    password=x5gUjs
    database=ts3db
    socket=
    [config]
    host=localhost
    username=teamspeak
    password=x5gUjs
    database=ts3db
    blankline
    that the correkt
    doesn't work.........
    no other ideas ?
    Mar 2005
    51
    Quote Originally Posted by BlackScript View Post
    no other ideas ?
    must work ..
    and you must give a Empty Line into it ..
    tested and its working to me with this solution since beta 5 (thats where i tested it)
    in german:
    blankline = leere zeile.. dies komischerweise ganz wichtig
    Aug 2008
    German
    78
    DELETED...
    I get the problem solved itself.
    Jun 2010
    UK
    Since this thread is the first place you land on when searching for the error on Google...
    This problem is caused on Windows by not escaping the backslashes on the dbpluginparameter parameter, i.e. you need something like:
    dbpluginparameter=C:\\Path\\ts3db_mysql.ini
  1. TeamSpeak with MySQL > 4.0
    By mokum in forum [TeamSpeak 2] Server Support
    Last Post: 02-10-2009, 21:03
  2. Connecting to Teamspeak VIA website ..
    By {BB} KnifE in forum [TeamSpeak 2] Client Support
    Last Post: 15-08-2009, 01:22
  3. connecting teamspeak server to remote mysql database
    By goarack in forum [TeamSpeak 2] Server Support
    Last Post: 11-06-2009, 03:10
  4. Web interface timing out
    By J_Campbell7 in forum [TeamSpeak 2] Server Support
    Last Post: 10-02-2008, 16:36
  5. Linux server dependecies
    By nwerensteijn in forum [TeamSpeak 2] Server Support
    Last Post: 05-09-2007, 21:23
