Results 1 to 2 of 2
    Dec 2009
    Canada
    Custom Sound Packs & Inactive Channel Switch
    There are a couple features I'd love to see. First is the sound packs, I would like to be able to have a mix between WAV and TTS. I like hearing client's phonetics, but I prefer the WAV sounds for everything else.
    The other feature is one from Ventrilo, where the host could set the server to move someone who hasn't talked in a while to a separate channel (An AFK channel).
    So far, I'm loving the quality and functionality of this program. Thanks.
    Jun 2008
    Krün, Germany
    464
    Regarding custom soundpacks: The client already fully supports this.
    * Go into C:\Program Files\TeamSpeak 3 Client\sound (or whereever you installed it)
    * Copy the default folder and rename the copy to "MySoundPack" or whatever desired
    * Open MySoundPack\settings.ini and adjust the name on the top
    * Feel free to edit the file. Alternatively, if you set the readonly flag on 0 in the ini file, you can also edit the sound script directly from the client.
    An idea might be a button near the soundpack dropdown box which automates the above process. Like "Clone soundpack" or somesuch.
  1. No Sound
    By tank464 in forum [TeamSpeak 2] Client Support
    Last Post: 18-11-2009, 19:16
  2. dos attack i think
    By sklipnoty in forum [TeamSpeak 2] Server Support
    Last Post: 29-08-2007, 23:19
  3. Timeout nach 30 Sekunden
    By NNNChef in forum [TeamSpeak 2] Client Support
    Last Post: 09-01-2006, 21:05
  4. Feature Requests (and Bribe) for TS3
    By jaym in forum [TeamSpeak 2] General Questions
    Last Post: 18-09-2005, 21:45
  5. Constant timeouts and disconnections
    By SniperBait in forum [TeamSpeak 2] Client Support
    Last Post: 10-05-2005, 22:07
