Results 1 to 1 of 1
24-12-2009, 03:04 #1
-= TeamSpeak User =-
- Dec 2009
- Location
- Aperture Laboratories
- 1
Yet another Segmentation Fault (while using the microphone)
This fatal error occurs everytime I try to do anything that has something to do with sound recording, i.e. testing the microphone or just connecting to the server so ts3 tries to record my voice.Code:ms@mintux ~/ts/TeamSpeak3-Client-linux_x86 $ ./ts3client_linux_x86 2009-12-24 03:48:07.793662|INFO |MPSingleton | | Detected local codeset to be: UTF-8 2009-12-24 03:48:07.794943|INFO | | | Logging started, clientlib version: 3.0.0-beta6 [Build: 9502] 2009-12-24 03:48:08.040433|INFO |ClientUI | | Failed to init text to speech engine: 3584 2009-12-24 03:48:08.040622|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.0-beta6 [Build: 9502] 2009-12-24 03:48:08.040694|INFO |ClientUI | | Qt version: 4.5.3 2009-12-24 03:48:08.040779|INFO |ClientUI | | Using configuration location: /home/ms/.ts3client/ts3clientui_qt.conf 2009-12-24 03:48:08.537378|INFO |ClientUI | | Last update check was: Do. Dez 24 03:17:01 2009 2009-12-24 03:48:12.952044|INFO |PreProSpeex | 1| Speex version: 1.2rc1 Segmentation fault ms@mintux ~/ts/TeamSpeak3-Client-linux_x86 $
Skype works for me and TS2 work too (the linux versions of both). I'm running a Ubuntu (Mint) Linux and I'm using a USB Headset.
I did this 4 times, the kernel ring buffer log shows this:
I think this is an issue with the software, so I hope that someone is going to fix this anytime.Code:ts3client_linux[4752]: segfault at 157423d ip b00c69e8 sp af076070 error 4 in libasound.so.2.0.0[b0079000+c3000] ts3client_linux[4815]: segfault at 15 ip b52839e8 sp b40fd070 error 4 in libasound.so.2.0.0[b5236000+c3000] ts3client_linux[5872]: segfault at 9b ip b51859e8 sp b4135070 error 4 in libasound.so.2.0.0[b5138000+c3000] ts3client_linux[6048]: segfault at 131d510 ip b5af99e8 sp b4a90070 error 4 in libasound.so.2.0.0[b5aac000+c3000]
Segmentation fault
By Garog in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 15-01-2009, 17:51 -
Runtime Error 0 Segmentation fault
By Psybertech in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 15-08-2006, 23:56 -
Segmentation fault while runing teamspeak
By W0lf in forum [TeamSpeak 2] Server SupportReplies: 1Last Post: 17-07-2005, 16:41 -
Segmentation Fault! Arghh!
By Brigand in forum [TeamSpeak 2] Server SupportReplies: 0Last Post: 29-01-2004, 18:32 -
Segmentation Fault
By Lange in forum [TeamSpeak 2] Server SupportReplies: 40Last Post: 13-01-2003, 11:44
