Results 1 to 12 of 12
25-12-2009, 20:28 #1Breslau Guest
How To reg Server + Max Clients: 512
i dont see any topic with this so i made some tut how to..
This tutorial is about first install you TS 3 Server!
1 : go to http://npl.tritoncia.com/ts3npl.php and simple register.
2 : now you wait to get some e-mail from npl.tritoncia.com
3 : confirm this e-mail info.
4 : for now you must wait for e-mail with some file "licensekey.dat"
5 : just copy this "licensekey.dat" to the you TS 3 server root location.
simple first start server.
Now you can edit max users in you server.
good luck.Last edited by Breslau; 26-12-2009 at 13:28.
25-12-2009, 21:02 #2
-= TeamSpeak User =-
- Dec 2009
- Location
- Germany
- 7
Well, i registered myself on tritoncia.com
I got the email with the "licensekey.dat".
Now i Stoped my server, uploaded the "licensekey.dat" and Started the server again.
But i canīt edit max users! it is still 32 and "grey"
I started the server several times, but no change...
The "licensekey.dat" is in the root as it have to be.
TS3 root = /folder/teamspeak3folder
Sry for my english...
25-12-2009, 21:04 #3
-= TeamSpeak Addict =-
- Dec 2009
- Location
- Norwich, UK
- 140
If using ts3server.ini
licensepath=licensekey.dat
If using command line launch add
on the end.
25-12-2009, 21:09 #4Breslau Guest
is simple
just try, reinstal server .
1. delete all files from you root location on TS3.
2. upload server files to this same location.
3. start server and save all info from console ( serveradmin pass , and token)
4 . now edit you virtual server.
you not have some permission to change max users coz you have old logs and information about serwer.
Sory for my english 2.
now he must working with edit max users!
25-12-2009, 21:19 #5
- Dec 2009
- Location
- Germany
- 7
@jwevrsn
is this correct?
screen -A -m -d -S teamspeak3 ./ts3server_linux_amd64 licensepath=licensekey.dat
This solution doesnīt work
@Breslau
Omg... reinstall??
All permissions lost?
Create all Channels new?
Damn...
is this the only solution?
25-12-2009, 21:38 #6
-= TeamSpeak Lover =-
- Dec 2009
- Location
- USA
- 58
You need to put yourself in the Server Admin Query group or a group that has the b_virtualserver_modify_maxclients permission.
25-12-2009, 23:04 #7
- Dec 2009
- Location
- PA , USA
- 3
I regg'd for my key about a week ago and still haven't gotten my key yet.. is there a long turn around time form them to process my form?
25-12-2009, 23:09 #8Breslau Guest
25-12-2009, 23:11 #9Breslau Guest
27-12-2009, 05:10 #10
- Dec 2009
- Location
- USA
- 7
Please do not try again. You can email Triton at sales@tritoncia.com and explain the situation and they should be able to help you from there. You might first check your spam folder as it may have ended up in there as well.
27-12-2009, 12:15 #11Breslau Guest
27-12-2009, 16:31 #12
- Dec 2009
- Location
- Germany
- 7
Hey,
you need to give your Client the Permission 100 rights to change the number of max users.
jwevrsn wrote a very nice tutorial on how to do that, which you can find here:
http://forum.teamspeak.com/showthread.php?t=46779
If you follow these steps, you can change the number of maximum clients with the "edit virtualserver" function of your client
Have fun!
Edit: I forgot one thing, that I got asked a couple of times now by some friends who had some trouble with the tutorial, so I thought I would insert it here:
At one point you need to enter the line "servergroupaddclient sgid=2 cldbid=2" (according to the tutorial). That is great and correct, if the number of your client is indeed "2". If your number is diffrent, then you can adjust the entry to "servergroupaddclient sgid=2 cldbid=(insert client number)".
Router problems
By bigteam0385 in forum [TeamSpeak 2] Server SupportReplies: 4Last Post: 24-05-2011, 10:53 -
TS3 server - initial install issues - please add comments here
By mrwoo in forum WindowsReplies: 1Last Post: 13-05-2010, 02:46 -
Clients Can't Log in to TS3 Server. Help!!!
By Pescao6 in forum WindowsReplies: 3Last Post: 25-12-2009, 09:25 -
Cannot connect to server by LAN or WAN
By Basti504 in forum [TeamSpeak 2] Server SupportReplies: 5Last Post: 25-11-2007, 22:30 -
Server stops responding
By Xeroed in forum [TeamSpeak 2] Server SupportReplies: 10Last Post: 27-09-2006, 04:08
